Question about Rowenta Perfect Iron
Its gone off!
The green light is flashing on my steam generator and it will not heat up, i have lost the instruction book and dont know weather it is something simple or if i need a new iron! can you help?
regards Joolz
  • jar1947 May 13, 2008
    I own a Rowenta DE-831 Professional inox. The green light keeps blinking and making a clicking sound when I have water in the chamber so I can steam iron. If I remove the water and turn the iron back on occasionally, I can get the iron to heat up but I can not get it to steam iron. I would even be willing to take it to a repair shop if I could find one. I love to iron since I got my Rowenta.
    Jo Ann R.
  • 24 Answers
This iron show green, it definitely have to be hot on the sole plate. These case confirm is the electronic device is faulty.
Regards
alan
Posted on Feb 26, 2008
Fill the reservoir completely up with water and hit the reset button (on the left) for the water. You should hear a buzzing sound and the green light should go steady again.
Posted on Feb 23, 2008
    Scholar:
  • 70 Answers
The green light indicates the unit thinks it is out of water. Take of rewervoir; make sure the inlets are not plugged. Open the little plug on side, clean tank w/ clear water only, and shake out all water completely. Put it all back together, but leave reservoir off. Turn on and run unit "dry". Your should hear a "flutter" sound as the unit trys to pump water from missing reservoir, the heater/steamer should be sizzling hot & pressurizing. THEN the green light if ome ON, asking you to switch it off, refill & install the water reservoir. If things don't happen in that sequence, you should be able to determine what is wrong.
Posted on Feb 02, 2008
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
Calc-clean function light keeps flashing
Press the reset button
Nov 12, 2013 | Irons
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
No steam. I pressed the steam button on the underside of iron handle and no staem.
There 's a leaked capacitor in the circuit board. You just have to replace it and it works again.
Please visit the following page for detailed instructions:
http://thechipfreak.blogspot.com
Jan 15, 2010 | Rowenta DG5030 Iron
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Have just bought kenwood steam generator iron but there are no instructions with it. the filter light is flashing what do i do
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Aug 31, 2009 | Irons
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Lost my instruction book for tefal pro expres iron
Hello might be able to help you with the book
What country are you in?
Feb 14, 2009 | Tefal Irons
Steam generator iron beebs when button pressed but no steam green flashing light on aswel
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 21, 2008 | Euro-Pro Steam Generator EP8001 Iron
Hi i have an edbs920 steam generator iron, my problem is that it will dry iron but wont steam up anymore, after turning the system on the power indicator light should turn from the flashing orange pre...
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
Apr 30, 2008 | Euro-Pro Steam Generator EP8001 Iron
Rowenta Perfect Iron Logo
574 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
