Question about Car Audio & Video
Sirius radio connection
I just got a Durabrand DB1215 radio and was wondering if I can connect my Sirius radio directly to it using the aux input on the front of the radio
Yes, just plug it into the AUX port and keep pressing the mode button until it says "AUX" on the display!
Posted on Aug 10, 2009
I'm considering purchasing a Sirius Stiletto 2 Satellite Radio Receiver - just wondering if it can it be connected to my new Harmon Kardon 3600 avr or do I need to buy the Sirius connect SCH1 Home...
You will need to use the aux input from the top of the unit, or from the back of your home dock. If your receiver has a built in or add-on dock for the XM2GO line of radios, you will need to read here: http://www.digitalradiocentral.com/sirius-backstage/stiletto/108379-i-converted-xm2go-dock-stiletto.html
Jan 08, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
Kenwood Kdc-mp425 will not switch to Aux. Aux cable is connected to the back of the headunit, but no aux option is available on menu for either my ipod touch or my sirius unit. I've accessed the menu from...
Apparently, this auxiliary input only works for a Kenwood CD changer or a sirius radio connection. At least that is my conclusion after finding the same problem. Let me know if you figured anything out on this.
Jun 02, 2010 | Kenwood Sirius KDC-MP425 CD Player
I have a sirius ready cd player installed in my jeep. I was wondering how I get sirius radio..when you scroll through Cd,radio, aux , there is sirius so i dont think i need another radio...but i dont know...
Looking at the user manual on page 13, you have to purchase and connect the XMD1000 module to in order to get the satellite radio service. If the module is installed, you'll get a display telling you to sign up for service.
Feb 24, 2010 | Panasonic CQ-C7301U CD Player
I have a Sirius Stiletto 2 radio. How do I
NO there is no line input jack the AUX button was made for the rear video system
but there is a audio adapter you can use go here
to read more about it
FRD04-AUX
Dec 28, 2009 | 2006 Ford F-250 Super Duty
Tone in sirius radio using aux. input
Do you have a thicker audio cable you can use? It might cut down on the interference that way.
Mar 16, 2009 | Sirius Satellite Radio Receiver
Sirius question
Yes it should be very easy with use of the ear phone jack - depending on the model of course but generally all you need is an ac/dc power supply, the antenna connection, and for connection to receiver you can connect via FM or hard wire.
FM: as in your car pick an FM station frequency that is clear (no station on it) lets say 88.1 then set your home receiver on 88.1 and there you have it.
DIRECT: purchase a stereo 3.5mm headphone cable with two RCA male plugs at the other end. A faily common cable found in dollar stores or for five times the price at Walmart/Radio Shack etc.. Plug the 3.5mm plug into the 'headpone' jack of the satellite radio and the RCA plugs into the rear of your home receiver - usually a 'aux/line in plug" or "tape in" plug then turn the knob on the receiver to "aux or tape" selector. Bingo you should hear satellite radio all over the house....if the volume is UP! Take care Frank
Sep 05, 2008 | Sirius Satellite Radio Receiver
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
SIRIUS RADIO
that unit has aux inputs in the back they are rca level inputs.. your "stratus" has an audio output that is a 3.5 mm jack or standard headphone jack, with the appropriate patch cord, you can connect the two devices giving you the best possible sound quality. you would use the aux source on the head unit to listen to sirius. this feature may need to be turned on in the menu.
Feb 10, 2008 | Panasonic CQ-C8303U CD Player
Only on/off chimes come through radio
The input source is controlled by contacts in the actual input on the side of the radio. It sounds like the contact for an aux connection is stuck closed. The contacts need to be separated, and probably the only way to do this is to disassemble the radio. If it is under warranty (less than a year old), I would suggest calling SIRIUS warranty for a replacement. If not, and you don't feel comfortable taking the unit apart, find someone who is because the unit is most likely salvageable!
Jan 03, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
"buzz" when Sirius receiver is plugged into AUX input of new Camry
Did you have the unit installed at a shop that would have hardwired the power source? It sounds like either your power wire to the sirius unit is connected to a noisy power source (which is why you are picking up the alternator whine), or you have a poor ground connection to the unit. If it was installed at a shop, take it back and have them move the power source to the same wires that the radio gets power from. If you are using your cigarette lighter for power, unfortunately it sounds like your outlet doesn't give you the best source for powering an audio component. You might try stopping by a car audio shop and ask how much it would cost to hardwire the sirius' power to the back of your radio.
Nov 07, 2006 | Sirius Satellite Radio Sirius Starbase...
Car Audio & Video Logo
470 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
