Question about GE Profile Prodigy WPSE4200A
GE profile prodigy washer
I washed a quilt in my washer and the frays and lint were horrible. I cleaned out the pump that was clogged and now the washer does not aggitate or spin. HELP HELP HELP. My husband told me not to wash it in my washer but I was stubborn and did it anyway. So not only is my washer broke my husband is mad. Help a stubborn woman would you?
  • svorhees Jan 08, 2008
    The water pumps out just fine. It just doesn't aggitate or spin now. I hear the motor running but no movement of tub? Do I still try what you said before?
  • 264 Answers
It is a easy job you will have to take out the pump and all the hoses that are connected to the drum only the bottom ones ok then start to fill the machine with water do this out side if you can you do not want a fluid as well just keep putting water in the soap draw make sure there are no wires that can get wet if every thing is out the way plug the machine in and put it on a program only on spin only that way water will get a round the drum keep doing it and all remains will come out when done put pump back and pipes and put back in the kitchen and put it on a rinse program and let it pump out if it do all that then you have cleared it and give your self a pat on the back if you haven't done it you should go down you local second hand shop that do appliance and tell them and they might take on the job and save you time and money hope i have helped you
Posted on Jan 07, 2008
Where is the lint screen on a GE prodigy profile top load washer?
most top loader flint collectors are in the top of the agitator where you put in the comforter fabric softener. Pull this section up and the lint sock will be at the bottom of it
Apr 01, 2013 | GE Profile Prodigy WPSE4200A
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
Washer not draining/pumping out water
There is an instruction sheet in the control console. It will explain how to open the washer.Once inside the washer, clean the pump hose and the inside of the pump. It will be on the bottom right hand side.You will have to disassemble the pump to clean it.
Apr 08, 2009 | GE WDSR2080D Top Load Washer
GE profile prodigy - dyer
hi. the vent inside the dryer needs to be must live in a warm climate. clean all air vents inside the dryer, and out. thanks the appliance doc
Oct 04, 2008 | GE Profile Prodigy WPSE4200A
Ge washer # WBVH6240FWW
We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
Aug 15, 2008 | GE Profile Prodigy WPSE4200A
Ge prodigy wpse4270aoww won't rinse or spin
try to clean out the water pump lines from pump to out to the drain
Feb 25, 2008 | GE Profile Prodigy WPSE4200A
Fixing a clogged pump on GE Profile washer
Take a putty knife and slide it in between the front panel and top to pop the clips that hold on the top. Remove the front panel and you will see the pump down in the front corner. Remove the hoses (watch for water) and you should see any clog. Check hoses and drain line (home) to be sure there is no clog in those while you have it apart. Be sure to unplug your machine before working on it as well. Good Luck!!! Jim
Sep 09, 2007 | GE Profile Prodigy WPSE4200A
Will not drain during spin???
Most likely your outlet filter of the machine is choked with dirt or something; clean out the filter & refit. Of course after taking of the wall plug & siphoning out the water from washer.
Sep 21, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
235 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
