Question about Sony DVD/VCR Progressive Player
VCR Video Signal from Combo Unit Seems Messed Up
An old VHS VCR that I connect by composite video through my new AV receiver began showing splotchy images, with colors undulating across the screen. The image from the separate DVD device is great. Thinking that the VCR had worn out, I replaced both the VCR and the DVD with a new combined unit from Sony. I connect the new device through the composite video connectors. Once again, the DVD signal is great, but the VCR signal displays the same problem, even though now both signals are running across the same cables. (Sound is normal for both DVD and VCR.) I tested several tapes and got teh same result. I am now wondering if the issue is my cables (which are tucked tightly together into a cramped cabinet area). My hypothesis: The DVD image is great because it is a digital signal, but theVCR signal is messed up because I am getting interference into my cheap cables, messing up the VCR's analog signal. Does this hypothesis hold any water? If this is the case, can I solve the problem by buying better composite video cables? Is there something else I should be considering? Sure will appreciate your thoughts.
JMuskovitz
  • 135 Answers
SOURCE: Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Posted on Mar 22, 2007
jackboy
  • 2985 Answers
SOURCE: cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Posted on Jul 31, 2007
  • 3 Answers
SOURCE: Recording tv programs etc
I had same problem. With mine i could record wo the digital cable box but not with it hooked up. Would love to get some info about it.
Posted on Aug 25, 2008
mistersony
  • 320 Answers
SOURCE: SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Posted on Nov 02, 2008
  • 3 Answers
SOURCE: Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
Posted on Jun 02, 2009
How do I connect old school dvd/vcr combo to LED HDTV?
The general rule of thumb is that R-W-Y outputs from the VCR/DVD combo plug into corresponding color coded inputs on the TV. I think the Y(ellow)/VIDEO designation indicates where to insert the Y cord. It's worth a try.
Feb 12, 2016 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Having trouble hooking old VCR up to new LG TV and Integra Receiver. Feel like I'm missing a step...
Look at the back of the tv. What is it labeled at where you plugged the VCR into. Should probably say composite in. After that's verified, go into the tv menu and make sure you have selected composite input. Should be no need for any settings on VCR, it has to be settings on tv
Jan 11, 2013 | Panasonic Omnivision PV-7401 4 Head VHS...
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
Problem connecting DVD/VCR to DISH
Dish dvr can only output so you have to connect your dish dvr to your dvd/vcr and then connect your dvd/vcr to your tv and im sure it should work
Dec 19, 2009 | Televison & Video
I can play DVD's but not VHS tapes. I hav checked all connections and several tapes to no avail. Thank you ! Ol' Fred
Hey Ol' Fred...
One of my good friends is an ol Fred so I felt compelled to stop in and help!
I'm not sure of your setup, but if you've got a combo DVD/VHS unit, make sure that you have out puts to the TV for Both parts separately... You can designate by accessing the TV's onscreen menu and setting up a separate source for DVD and one for VHS. I've found on my projection TV that it's best to use the Coax cable connections for the VHS to TV.
Then once it's setup with separate hookups to the Tv, you should have audio and video for VHS...
k
Dec 18, 2009 | Televison & Video
Trying to dub from dvr to vhs vcr
Is L2 for composite video (yellow) or S-Video? Try watching a video on L2 with the composite video plugged into the back of your TV, if it works, then do the same with the DVR, if that works, then run the DVR composite video into a receiver, then the L2 from the VCR to the video out on your receiver. It's possible that the VCR won't record anything that isn't an applified signal. That's what the receiver does.
Oct 01, 2009 | Sony RDR-VX555
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Dec 17, 2007 | RCA F32650 32" TV
Mar 22, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
