1999 Chrysler Sebring Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the located fuel filter on my 1999 chrysler sebring, for i am having problems with it. thank you
Marvin
Level 3:
Top Expert:
  • Chrysler Master 85,242 Answers
  • Posted on Oct 15, 2009
Marvin
Chrysler Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29059244
Points
266281
The fuel filter is mounted on the frame above the back of the fuel tank. Remove the fuel pump relay from the power distribution center, then start the engine. Allow it to run until it stalls. Try to start it again and let it run until it stalls. Repeat this procedure until it no longer will start, then turn the ignition off.
  • Step 2 Loosen and lower the fuel tank assembly to get to the fuel filter. Disconnect the negative battery cable. Open the trunk and find the 4-pin connector under the trunk mat on the left side near the base of the shock tower. Disconnect the fuel pump wiring jumper from the body harness.
  • Step 3 Push the body grommet out and feed the jumper completely through the hole in the body. Relieve the fuel system pressure by slowly removing the fuel filter cap. Raise and support the vehicle.
  • Step 4 Put a fuel container under the drain plug, which is on the bottom-left of the fuel tank. Remove the plug and let the fuel drain out. Reinstall the plug and tighten it to 32 inch pounds.
  • Step 5 Disconnect the driver's side fuel tank strap and loosen the passenger's side fuel tank strap. Squeeze the fuel filter hose connector to release the tabs and disconnect the fuel lines. Then, take out the fuel filter.
  • Step 6 Put a bit of engine oil on the ends of the new fuel filter. Connect it to the fuel tubes. Reposition the fuel tank and put the fuel tank straps back on, tightening the bolts to the bolts to 17 foot pounds. Reconnect the fuel pump module connector.
  • Step 7 Connect the negative battery cable. Refill the fuel tank and wipe up any fuel that may have spilled during the filter replacement. Check for fuel leaks when you start your Chrysler Sebri
  • Greg Bernett
    Level 3:
    • Chrysler Master 2,993 Answers
    Greg Bernett
    Chrysler Master
    Level 3:
    Answers
    2993
    Questions
    Helped
    2783092
    Points
    13428
    Look here first....tell me if you find it:
    A replaceable fuel filter is located in the engine compartment, on the bulkhead, next to the brake booster.
    1helpful
    I have a 1997 sebring lxi. It now will not turn over. I sprayed starter fluid in the intake and it turns over. I changed the fuel pump, fuel filter, and the relay. What else could it be?
    Do you hear the fuel pump coming on normally comes on for approx 10 sec. when you turn key on, if no pump noise fault is still in fuel system, check the fuse and wiring, check for trouble codes, check injectors, etc
    links below may help trouble shoot, press the helpful button
    http://www.geeksoncars.com/how_4896626_troubleshoot-pump-problems-chrysler-sebring.html
    1999 Chrysler Sebring LXi V6 2 5L
    How to Test the Fuel Pump Chrysler 2 0L 2 4L
    Where is the fuel filter for the 2007 chrysler sebring 6 cylinder / 2.7, located?
    i beleive the fuel filter is above the fuel tank and the tank will have to be lowered to gain enough access to replace it.
    1999 chrysler sebring convertible jxi code p1495 intermittant shut off while driving. Replaced fuel pump and filter, distributor, spark plugs and wire. Was advised by ZJLimited to remove connector from the...
    replacing the fuel pump relay is one thing but what about the (ASD auto-shut down) relay
    additionally...
    • what engine size?
    • what transmission?
    • any codes?
    • does the pump run KOEO?
    • Do you have spark?
    • What is the cranking speed?
    you may find faster service by subscribing to a "live chat" since there are so many questions and variables in your concern
    6helpful
    Where is the fuel filter located on a 2004 Chrysler Sebring sedan?
    Some of the Sebrings have two filters(one is called a sock).The sock(which all sebrings have) is located in the fuel tank itself on the pump module.If this model is the JXI then the external filter is located on the belly of the car between the tank and drivers rear seat. I hope I could help!!!
    7helpful
    2answers
    1999 Chrsler Sebring LXi v6 2.5L. Car dies.
    I had the same problem with my 1999 Chrysler Sebring 2.5L V6 Convertable. It started stalling at intersections; would lose RPMs' and die while driving it; and would not start unless it sat for a few minutes. Once it started, you'd have the scenario start all over again...
    I hadn't kept up my maintenance schedule like I usually do, so I did the usual; I replaced my spark plugs and wires, changed the oil and filters, ect...
    Finally, after it doing the same thing and wasting a ton of time and frustration on the side of the road, I took it to a mechanic that put it on his $9,000 diagnostic machine. The verdict; CRANK SHAFT POSITION SENSOR!
    The Haynes Manual will tell you wrong on its location for the 1999 Lxi 2.5L V6 convertable; it is NOT LOCATED BEHIND THE BATTERY TRAY. The crankshaft position sensor is actually located about 4 to 6 inches below the distributor, which is about dead center of the motor, on the transaxle housing.
    You do have to take off the tire and the skirt cover to get to it. I had to purchase two long socket extensions just to get to the bolt that mounts the sensor to the transaxle housing; but it was well worth the 20 bucks...
    All in all, it took me three hours to find the damn thing, and then to figure out what I needed to take the old one off and get the new one installed.
    The $65 dollars that I spent to find out what the problem was is worth it....
    Now, the car runs better than ever....
    1helpful
    2answers
    I can't locate the fuel filter on my 2004 chrysler sebring 6 cyl coupe (3000).
    I would check if it is in the gas tank on that model. you can go to your local parts store and they should be able to inform you of this.
    4helpful
    2answers
    Where is the fuel filter on a 99 chrysler sebring lxi
    The fuel filter on the Sebring is tucked up next to the tank towards the passenger side rear wheel. You can to pick up the fuel filter from Advance Auto Parts or Auto Zone for $25.00 Purolator Fuel Filter Part Number: F55302 Good luck and hope this helps. Auto Zone can give you the step by step to replacing the fuel filter free of charge.
    2answers
    Fuel filter
    fuel filters are usually located under the driver side of the car. it will be a metal cylinder with 2 lines on it. one going to the engine and one coming from the gas tank.
    Top Chrysler Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    john h
    Are you a Chrysler Expert? Answer questions, earn points and help others
