Question about Philips 32PT6441/37 32" TV
Staining on LCD tv screen
Looks like some one has split something down the screen but nothing has been spilt. The mark seems to be inside, but the screen looks okay when the TV is switched off. Have you any solutions to this.
  • Anonymous Oct 12, 2008
    there is a dark mark like a stain when the tv is on. Wiping doesn't help. It shows up when the screen has an open expanse like a cricket field.
    Sergeant:
  • 395 Answers
The LCD screen is bad this may have been caused by presure exerted to the screen fracturing the cells of the LCD. any way the LCD is bad and needs replacing.
Posted on Jan 01, 2008
I have a Sanyo Vizon DP42647 that was given to me. Everything seems to work great except it looks like red Kool-Aid was poured on the screen. Can it be cleaned or just pitch it
I think it is more than a Kool-Aid stain. likely it was some kind of heat applied to the screen causing physical damage. How does it appear when the screen is white?
Aug 20, 2014 | Sanyo VIZON Multisystem 42" LCD TV 110-220...
Dark shadow on lcd tv screen
I've seen a few of these.
They don't seem to be an indicator that the set is going to fail soon. The only fix seems to be to replace the screen but that is more cost than replacing the whole TV.
Mar 02, 2013 | ViewSonic N3735W 37 in. LCD TV
Sanyo TV DP42647 Screen Has Dark Stain
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 27, 2017 | Sanyo Televison & Video
I have what can only be described as a stain on the screen of my 32 inch lcd phillips. its only on part of it from the top mid half way down ,looks like a water mark.
I assume this stain is internal? From your description it sounds like a flaw or fault within the screen. The only solution would be to replace the screen
Aug 17, 2009 | Philips Televison & Video
Spreading brown stain on screen
your LCD panel is damaged, if it is only a year old it should be under warranty, it needs to be repalced.
Jun 11, 2009 | Acer Aspire 5720-4230 Notebook
Gray cloud
If the stain is irregular and static that is a faulty LCD display. The repair is expensive. Contact Polaroid at the number listed on owners manual as the TV has one year factory warranty cover.
May 15, 2009 | Polaroid TLA-04011C 40 in. LCD TV
My lcd has a big stain, but it seems to be inside the screen, I had tryed to clean but it not desapear, I think i shall clean it internally, but i dont know hot to disarm it.
If it looks like a big stain usually that means some of the liquid crystalline is leaking, you can't clean it. You'll have to replace the lcd in order to fix the problem.
Mar 10, 2009 | Acer Aspire 4720 Notebook
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
LCD Screen has a split and Samsung will not repair under warranty
I don't quite understand the problem - are you asking how to fix the spilt? How to fit a new screen? How to get Samsung to repair? You need to be clearer!
May 27, 2008 | Samsung Cell Phones
Looks like a water stain on screen
IT SHOULD NOT NEED A "REPAIR" PER SAY. HOWEVER, I OWN AN LCD TV, BUT NOT A PROTRON. YOU'RE GONNA FIND THIS PROBLEM WITH ALL LCD TV'S. IT SOUNDS LIKE IT IS SIMPLY DIRTY. THIS IS THE WAY YOU CLEAN YOUR SCREEN. IT IS VERY EASY AND FAST, AND YOU SHOULD HAVE THE SOLUTION IN YOUR KITCHEN AND BATHROOM. TAKE THE CLEANEST, MOST SOFT CLOTH YOU HAVE IN YOUR HOUSE. DAMPEN,NOT SOAK IT, WITH WATER, AND LIGHTLY RUB A SMALL SECTION OF THIS STAIN, AND SEE WHAT HAPPENS. IF THIS DOES NOT WORK, ADD A SMALL AMOUNT OF SIMPLE RUBBING ALCOHOL, AND TRY ANOTHER SMALL SPOT OF THE STAIN. IT SHOULD COME OFF. SOME OF MY "HI-TECH" FRIENDS USE STRAIGHT RUBBING ALCOHOL, AS IT HAS A TENDENCY TO EVAPORATE A LOT FASTER THAN WATER AND LESS LIKELY TO LEAVE ANY "WATER STAINS". HOWEVER, IF YOU CANNOT SEE THROUGH THIS STAIN, THEN YOU'RE BETTER OFF BUYING A NEW TV. SOUNDS LIKE SOME KIND OF LEAK OR MAYBE THE TV IS JUST NEVER SHUT OFF, THEREFORE BURNING IMAGES INTO THE SCREEN. FORTUNATELY, IF IT IS STILL UNDER WARRANTY, YOU MAY GET HELP THERE. MY FIANCE TOUCHED THE LCD SCREEN WITH HIS FINGERS, AND IF YOUR FINGERS ARE DIRTY, THEY WILL LEAVE OIL STAINS. PEOPLE DO SOMETHING TO A PRIZE POSSESSION IN YOUR HOUSE, DONT TELL YOU THEN ACT LIKE THEY DONT KNOW WHAT HAPPENED. ITS HILARIOUS. HOPEFULLY THE ISSUE YOU HAVE CAN BE FIXED BY YOU!
Jan 01, 2008 | Protron PLTV-32 Television
Philips 32PT6441/37 32" TV Logo
168 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
