Question about GE Profile JGS968 Gas Kitchen Range
Ignitor problem on GE Profile range
I didn't find the exact model below, but two of my ignitors don't work with their respective valve controls, but begin igniting along with one of the others that does work.
Any clue?
Greg French
gregf@studionorth.com
    Sergeant:
    Champion:
  • 310 Answers
They might need to be cleaned and adjusted into the flame
Posted on Jan 01, 2008
I have a GE Hotpoint stove/range model num 317B6641P001 that the oven will not ignite nor will the igniter turn on.
It sounds like the ignitor is bad...you will not or should not smell gas if ignitor is bad...gas valve is not supposed to open until the sensor by the ignitor has reached a certain temp. It's a safety feature. If you replace the ignitor, it should work like normal.
Jan 31, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
GE profile JGSP44 Oven stopped working
Ignitor needs to be working for the gas valve to open. If the ignitor does not reach the proper amp draw the gas valve will not open. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru performing an amp draw test on the ignitor.
Mar 28, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
Bake does not work
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Dec 11, 2009 | GE Profile JGSP48 Gas Kitchen Range
No oven baking function
You need to replace the oven ignitor. The ignitor has to draw enough current to open the gas valve. Your ignitor is either broke or not working properly, so the ignitor will not lite the oven.
Jan 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Short on range wont work
Check for power to the primary transformer on the control. You probably blew out the controller if you find 120 volts present to the board. You may also have blown the coil on your gas valve. Be careful here!
Dec 12, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Similar problem but ignitor replacement did not fix mine
try the gas valve behind the storage drawer. it may be closed. that was my problem.
Aug 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven gas valve wont come on
your valve is bad replace it the ignitor needs to darw a min of 3.5 amps to open the valve if it is drawing the amps then the valve is bad
Jan 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont start
The control sends voltage down to the ignitor, the ignitor glows red, when and if the ignitor gets hot enough it opens the gas valsve to let gas in which is then lit by the ignitor.
If ignitor glows either the ignitor is bad or the oven valve
If the ignitor does not glow then either the ignitor is broken, the control is not sending voltage down, or the oven valve is bad and not sending voltage to the ignitor.
In most cases it is the ignitor which is the cheapest of the three parts
Oct 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven doesn't work
Oct 31, 2006 | GE Profile JGBP79 Gas Kitchen Range
GE Profile JGS968 Gas Kitchen Range Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
