Hitachi 43FWX20B 43 in. Rear Projection Television
Problem for Hitachi 43FWX20B 43 in. Rear Projection Television
No green color----all other colors seem fine and
By trlrman2004 on Oct 15, 2009
No green color----all other colors seem fine and pic is clear and sharp.
Solution #1
posted on Oct 15, 2009
Not Rated)
Professor007
Rank: Guide
Rating: 100%, 2 votes
The most likely cause is a bad (shorted or open) CRT driver transistor on the green CRT board. Also check the solder connections on the connector sockets for wires that get plugged into on the CRT boards (and check all the CRT boards; not just the green CRT Board).
The next most-likely cause is a bad green CRT. Try tapping (gently!) on the neck of the green CRT and see if you get any green flashing on the screen. If so, then you've got a bad green picture tube.
Note: I am assuming you are an electronic technician with at least basic knowledge of electronics, and that you know how to solder and test components like resistors, capacitors, diodes, and transistors. If not, you better defer this repair to someone more experienced.
Was this helpful?
Yes
No
Popular Solutions for Hitachi 43FWX20B 43 in. Rear
Questions and Unsolved Problems for Hitachi 43FWX20B 43 in. Rear
Do you recommend Hitachi 43FWX20B 43 in. Rear Projection Television?
Answer
Answer
the screen on our Hitachi is speckeled with blue dots why is this happening?
Answer
Hitachi 43FWX20 43 in rear projection TV 2002 red and green shadows on sceen. Sometimes powering off... (More)
Answer
The TV comes on and the red light next to the power button lights up then instantly turns back off... (More)
Answer
hitachi 43FWX20B 43in. rear projection has green streaks and spots on the plastic screen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
