Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer
I have a loose baffle in the tumbler of my dryer. Can I get to this by removing the front cover of the dryer?
  • indy-vfr Dec 28, 2007
    Thanks!!
  • 625 Answers
The top cover is fastened by spring like tabs on the machine rear. the front edge of the top merely clips to the front panel. the top needs to be removed to gain access to the bolts that hold the front panel on. these are inside the top corners of the machine. once these are out, the front cover should just pull up to remove. there may be a light connection and the door switch wires here too. then you can get to the screws that hold the baffles in place.
Posted on Dec 28, 2007
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
One of the paddles in the dryer tumbler fell off. How hard is it to open the lid and screw them back on?
Disconnect power then open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffle securing screws can now be re-tightened or reinstalled. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Oct 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
As dryer rotates, with clothes drying, it sounds like loose pocket change is loose in between the two tubs.........help!
the change gets caught in the three baffles that are attached to the drum.unplug the dryer,open the door and remove the two screws that hold the in place,remove the door,then remove the other two screws opposite the door screws and pull the front panel off.rotate the drum so one of the baffles are down in the right hand corner so you can get at the screws that hold the baffles onto the drum.try loosening the screws but you might have to remove the baffles to get to the change.let me know how you make out
Apr 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Loose baffles in Maytag dryer
To remove the top, you usually have to push a putty knife in at the top corners, from the front. This pushes a spring catch. On some Maytags, the front comes off, screws below the door area, and it swings out.
Apr 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag frontload dryer MDE9700AYW
take the door off. take the front panel off. take the belt off the tumbler. take the tumbler out. you should see the roller. everything is held with regular phillips head screws.
Nov 10, 2007 | Maytag MDE9700AYM Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
151 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
