Question about Samsung WEP200 Headset
Samsung wep200 charger won't charge...
I can't get my charger that came with the product to charge it!!!
I love the headset dearly, and I just got it yesterday, but no light turns on when it is in it's case, i have tried multiple outlets and it just won't seem to charge...
Idk. if it is defective or i'm not charging it right but that part looked pretty self explanatory.
  • safetywerks Dec 31, 2007
    When I plug in wep200 into charger, light won't turn on. What shall I do?
  • Anonymous Feb 04, 2008
    i have the same problem red light will turn on charging once i take it
    out no blue light. It won't turn on. Just started happening after a
    year. Not sure what to do?
SOURCE: reset samaung headset wep200
make sure its turned off. Press until light turns solid blue, now u can search for bluetooth device on your phone....
Posted on Nov 13, 2007
rajthegreat
  • 92 Answers
SOURCE: Charging
just open the main board
and clean with solution
and give a little bit of heat with smd
Posted on Jan 16, 2008
djnick989
  • 1067 Answers
SOURCE: Music from blackberry 8820 to Samsung WEP200 bluetooth headset.
cheak headphones maby went out output settings in the samungs cheak vol up
Posted on Jan 27, 2008
SOURCE: Samsung WEP200 Headset will not charge up
I am having the same problem! Have you had any help?
Posted on May 02, 2008
maklean
  • 1665 Answers
Another user tried 0000 just now and it worked immediately.
hold the button down for about fifteen seconds when you first switch on (you will hear the second beep)
Posted on Jun 01, 2008
It flashes blue three times then the blue light fades out and it wont work. have tried charging it .
You can buy a replacement very cheaply www.a4c.com/product/samsung-wep200-bluetooth-headset-black.html
Apr 03, 2014 | Samsung WEP200 Headset
Bluetooth Crashed, won't turn on or off (can it be reset?)
Is there any way you can phisically disconnect the battery, wait about 3 minutes, and reconnect it? This would force a reboot, or re-initialize the headset's programing.
If it does work, be sure to let the battery drain down to cut-off before placing it in the charger. That way, the charger will be "on the same page" as the battery's charge level. It's worth a shot if you can do that.
Mar 20, 2017 | LG HBM-235 Headset
Want turn on when charging green & red light flashes
Normally if you have a VXi, B250-XT on its charger and you are seeing both a Green and Red light the headset is changin over from charging to fully charged. The headset is designed to be able to use while it is on the charger however once you place it on the charger you must turn it on to reconnect to your phone before you can do this. Put the headset on and press the Multifunction Button for 2 to 3 seconds, you should hear two rising tones and the headset should reconnect with your phone. Note* your phone may require you to accept the connection request.
If the headset will not turn on either on or off the charger I recommend calling VXi at 800-742-8588 for warranty repair information. A headset that will not turn on indicates the unit is having an issue with one of its control circuits.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
My Plantronic 230/R explorer headset completely lost it's charge. When connected to its charging adapter the red light come, stays red for a few minutes then goes out without charging the headset device....
Dear Allen
Im strongly recommend you, buy a new original charger otherwise you can damage your headset.
The red light you saw probably because your charger is not compatible.
You can buy a new one via eBay.
Mar 03, 2011 | Cell Phones
My headset wont charge or turn on
If you have another charger to try for the device (USB directly into computer, etc) try that, if you still have the same problem locate a copy of your reciept and call samsung either by phone or email then from their website.
Rylan
Dec 15, 2010 | Samsung WEP200 Headset
Brand new from the box but not charging
I would immediately return the device. It sounds like either the headset or the actual charger is defective.
Hope this helps
Tim
Sep 09, 2010 | Samsung WEP200 Headset
When I plug my Motorola H710 bluetooth in to charge the light only blinks red and when I use it it never seems to turn on?!
Here's the instructions for charging.
Plug the Motorola charger into the end of
the headset.
The indicator light turns red when the battery is charging. It may take up to 1 minute for the indicator light to turn on. When the headset's battery is fully charged (about 2hours), the indicator light turns green.
From your information, it may very well be that the battery should be replaced if the red light doesn't go off as it should.
Here's a link to the full instructions. I hope this helps.
(Click here)
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H710%20QSG%20EN%20Generic.pdf
Feb 06, 2010 | Motorola Mobility H710 Bluetooth Headset
I have a H270 Bluetooth headset. I charged it
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Oct 27, 2009 | Motorola Mobility H270 Bluetooth Headset
Samsung WEP200 Headset Logo
346 people viewed this question
Top Samsung Radio Communications Experts
syaiful ridlo
syaiful ridlo
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
