Question about Mitsubishi WS-55807 TV
MITSUBISHI BLINKING GREEN LIGHT
I HAVE A MITSUBISHI (WS-55807) AND WHEN I PUSH THE POWER BOTEN THE GREEN LIGHT JUST FLASHES FOR ABOUT 3 SECONDS AND I NEVER GET A PICTURE. I KNOW HOW TO SODER SO IF ANY ONE KNOWS HOW TO FIX THIS PROBLEM PLEASE EMAIL ME AT kpaki786@gmail.com thanks
  • 2 more comments
  • MS JACKIE Dec 30, 2007
    I GET A BLINKING GREEN LIGHT BUT NO PICTURE PLEASE HELP EMAIL ME AT JACK1EBEASLEY@YAHOO.COM
    THANKS
  • SkeeJr Jan 05, 2008
    I have the same problem. Everything was fine last night, until someone pushed the A/V Reset button on the front panel. It turned off immediately and now when you push the power button, the green light comes on for a second or 2 and turns back off.
  • Anonymous Jan 11, 2008
    I have the blinking green light on a wd-62825, There are four sets with the same problem in the authorizied repair center in our town. The DM board is backordered and has been for months. The customer service rep I talked with (LYN) at Mitsubishi hung up on me. This is a widespread recallable defect that Mitsubishi is not addressing.
  • Anonymous Jun 28, 2008
    I have 3 blinking lights but the TV never comes on, there is no power nothing. Is this solved by replacing the fuses, or is there more to my problem Mitsubbishi model WS-A55
I've got the blinking lights also. Model # WS-55613. Does anyone know what the problem is?
Posted on Jul 28, 2008
I have the same problem as ms jackie all i have is a green flashing light and no picture
Posted on Jul 03, 2008
    Genius:
  • 1,694 Answers
IF all of you have same Mits chassis.......check fuses F9A04
and F9A05...if open, replace with 5 amp pico fuses AND change
out both convergence IC's, all on center board............
Part # STK392-570.............................IF DIFFERENT MODEL
than shown in thread, solution may or may not apply...T.
Posted on Jan 07, 2008
  • Vista Electronics Jan 11, 2008
    FYI to guest Jan 11..........a blinking green light symptom is
    common on many makes / models in TV repair.........
    1) a WD-62825 does not have the DM module failure you are
    describing / assuming four other sets have in your town.
    2) DM modules are repaired by qualified Mits techs......
    four 1000mf 25v capacitors replaced usual fix.
    Applies to WS-xxx13 Models......WD series Mits are
    COMPLETELY DIFFERENT TECHNOLOGY !
    That is why I qualified my Post with two big IF'S ! ! ! !
Tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
Aug 25, 2012 | Mitsubishi WS-55807 TV
Tv will not stay turned on
its a problem in your main board of the tv.
Oct 30, 2008 | Mitsubishi WS-55807 TV
When i go to turn the tv on the green light go on and then off. i did the coe test error code repeated 10 times
I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again
Jan 02, 2011 | Mitsubishi WS-55807 TV
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
replace the dmv pcb, replacing just the cap is a temp fix, that is if it works location number is c9624
Jan 11, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
WON'T STAY ON
That is a typical problem in the power supply. It could be a switching regulator that has i think 7 pins, but it gets the power supply up and running with around 157VDC. If that is missing the set won't power up at all. Where are you located. I'm in Louisville Kentucky. Let me know if that works for you. Keep in mind there are quite a few fuses in there too. so check those. I think on that model there is 7 or 9 fuses to check. Talk to you soon. Jay
Jan 14, 2008 | Mitsubishi WS-55807 TV
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
TV won't power up
Generally,first step is locate open pico fuse(s) in power supply,usually feeds convergence amps. Next,replace STK devices.Then,reset alignment in servicer mode.
Oct 02, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
1,345 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
