GE DBXR463EDWW Electric Dryer
Problem for GE DBXR463EDWW Electric Dryer
Is there any way to turn off the buzzer when the
By aerial826 on Oct 15, 2009
Is there any way to turn off the buzzer when the drying time is over...or at least turn it down?
Best Solution
posted on Oct 15, 2009
Very Helpful)
jsrock516
Rank: Guru  GE Washers & Dryers  Expert
Rating: 96%, 7032 votes
If the model number you have this listed under is correct, there is a buzzer module located inside the control panel. It is a fixed module, which means it cannot be adjusted. So, if you wish to get rid of the noise, you will have to unplug it. All you should have to do is UNPLUG the dryer and remove the back of the control panel. Disconnect any leads from the buzzer module and wrap them each in electrical tape to keep them insulated.
If you go to appliancepartspros.com you can view what I am talking about. The buzzer is listed as item 12 under the "Backsplash, Blower and Motor Assembly" heading. When typing in your model number use "DBXR463ED0WW. The digit before the that two letters is a "zero", not the letter "O".
If you have questions, or if you have not provided the correct model number, pease post back with the correct information so that I maybe able to assist you better. I hope this helps you.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
burdfrenzy
Rank: Wiz  Washers & Dryers  Expert
Rating: 84%, 66 votes
Unplug the dryer. Open up the control panel on the front where the knobs are at. The screws are sometimes in the back. locate the buzzer or buzzer switch and disconnect it.
Was this helpful?
Yes
No
Popular Solutions for GE DBXR463EDWW Electric Dryer
Questions and Unsolved Problems for GE DBXR463EDWW Electric Dryer
Do you recommend GE DBXR463EDWW Electric Dryer?
Answer
Answer
my dryer will not heat at all.Is this usually the heating element?I took the screws out of the back... (More)
Answer
low heat heater coils turn off after about a minute
Answer
Dryer will not dry clothes on first cycle. Dryer also turns on and off when the plug is moved, it... (More)
Answer
My Ge electric dryer, model dbxr463egww, will turn on and run for about 10 minutes and then kick... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
