Hoover U5750-900 WindTunnel Bagless Upright Vacuum
Problem for Hoover U5750-900 WindTunnel Bagless Upright Vacuum
Describe how to replace belt on hoover windtunnel
By sherrywinche on Oct 15, 2009
Describe how to replace belt on hoover windtunnel bagless
Best Solution
posted on Oct 15, 2009
Very Helpful)
Vac Belts
Rank: Wiz  Vacuums  Expert
Rating: 84%, 154 votes
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hoover U5750-900 WindTunnel
Questions and Unsolved Problems for Hoover U5750-900 WindTunnel
Do you recommend Hoover U5750-900 WindTunnel Bagless Upright Vacuum?
Answer
Answer
I have a Tristar Vacuum that needs some work. The electrical and motor are fine. The extension... (More)
Answer
I need to get to the motor of a Hoover Windtunnel u5750-900. I have taken every screw out that I can... (More)
Answer
have week suction when using the hose, how do i correct this problem
Answer
need agitator shield replacement for hoover upright 5750-900 along with 15" brush Thanks
Answer
Hoover Windtunnel U5750-900 Agitator brush is weak. It turns fine if I tilt the vacuum back, but it... (More)
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in , IL
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
