Question about Garmin iQue 3600 GPS Receiver
Changed battery garmin ique no backlight
Help need to repair backlight
  • Halmav Feb 01, 2008
    I have the same problem. Replaced the battery without trouble. Now the backlight won't come on. The brightness/contrast won't change either. Is it fixable? Are there any instructions out there to help?
  • Anonymous Mar 04, 2009
    I have no back light on my Garmin IQ3600
  • 174 Answers
Most likely you broke one or both wire that supply power to the LCD. There are two ribbon cables to the LCD and two (black, white) wire. The ribbon cable cables supply data signal to the lcd and the smaller cable is the digitizer signal. The power wire (black, white) wires are soldered to the circuit board. And since these are LED lights there is a plus and minus and they have to be soldered correctly.
But before taking apart the IQUE 3600 did you try adjusting the brightness level?
Posted on Dec 31, 2007
I fixed mine!!! Very delicate operation. My IQue has a ribbon cable with the two wires enclosed in the amber colored ribbon. I first unplugged the battery so I wouldn't short anything out and make a bigger problem. I used an exacto knife to slowly scrape the coating on top of each wire (to expose about 1/8 inch of each wire and only the wire). I then used a 15W soldering iron to solder a very thin wire to the ribbon cable coming from the digitizer (using tweezers to hold the wire). I cut the length of the thin wire, with sissors, to be able to reach the solder point at the end of the ribbon cable. I then soldered the wires to the solder point on the circuit board. I didn't touch the iron to the soldering point for more than a second so the wire wouldn't heat up enough to loosen the other solder. Making sure that the wires weren't touching, I finished by coating both wires and the immediate area with a silicon caulk. Hooked up the battery, put it back together, and I'm back in business.
Posted on Feb 11, 2008
I agree with audiqv8. After you have determined that the brightness level adjustment doesn't fix the problem and also checking to see if pressing the power on button a few times also won't fix the problem, carefully disassemble the cover again and locate the two small wires connected to the lower left hand corner of the screen and. Carefully try to press on the ribbon cable to see if you can get the leds to light up. If they light and you are good at soldering small connections you should be able to get the two wires reconnected (make sure you have polarity correct on the wires and you are back in business!
Posted on Feb 09, 2008
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Buy
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
kaufen
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
I just changed the battery on a garmin ique 3600 and the backlight won't come on. Any tips?
Most likely you broke one or both wire from the backlight to the circuit board. Open the unit up and look for a black and red wire. Both should be soldered to the circuit board. LED's are used for the backlight and so it does make a different that the back and red wire are soldered to the circuit board correctly.
Oct 04, 2009 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600 backlight does not work.
When you opened up the unit, you probably loosened one of the wires. Look to see if there is a small, short black wire and a small short red wire attached to the screen and soldered onto the circut board. They control the back light and one of them may be loose or disconnected. It can be repaired if you have a fine enough soldering tool.
Apr 11, 2009 | Garmin iQue 3600 GPS Receiver
Backlight for palm ique
Did You try holding dowm the on/off button for 3 seconds after you turn it on?
Mar 19, 2009 | Garmin iQue 3600 GPS Receiver
No backlight on my Garmin IQue 3600
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Feb 03, 2009 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600
Sounds like a battery problem and I ordered a new battery to see if that will fix the unit.
We will see!
A Sudia
Aug 26, 2008 | Garmin iQue 3600 GPS Receiver
Garmin IQue M5
Make a sprite backup to an SD card before changing battery. If you lose data just restore it from the backup.
May 31, 2008 | Garmin iQue M5 GPS Receiver
Repair center for Garmin iQue 3600
dont send your ique 3600 to raytech electr.i leaving at 5 min. from there and last week they tell me they dont repair the ique anymore they send back all there part to garmin they had to much problem with them good lock
May 25, 2008 | Garmin iQue 3600 GPS Receiver
GARMIN ique 3600 - need spare part
eBay or other online sites like that, search for sold 'as is' for parts.
However you can't have mine... it works just fine. ;>D
Sep 11, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
253 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
