Question about KitchenAid KCM511 Coffee Maker
Coffee not going into carafe
When coffee is making, only about a third is going into carafe. The rest is leaking out around the warmer and on the cabinet.
  • 2 more comments
  • PAMELA
    PAMELA Feb 15, 2008
    COFFEE GRINDS ALL IN THE POT AFTER BREWING. SOMETIMES IT LEAKS OUT. AND THE COFFEE DOESN'T GET VERY HOT.
    ALSO I NOTICED THAT THERE IS A LONG WHITE STICK WITH A PULL RING ON TOP AND FILTER LOOKING BASKET ON THE BOTTOM, THAT SIT WHERE YOU POUR YOUR WATER INTO THE COFFEE MAKER.
    I LOST MY MANUAL AND NEED TO FIND OUT MORE ABOUT THIS COFFEE MAKER
  • SuGon Mar 08, 2008
    I too have the same problem and have to watch the entire pot brew otherwise my counter ends up covered with coffee. I've had this coffeemaker for 2 months!
  • Anonymous Apr 07, 2008
    I have had to babysit this coffee maker everyday from the day I bought it. The only thing good about it is it pretty!
  • Anonymous Apr 04, 2009
    I have the same problem. If you do not hold the coffee pot in to engage the plastic lever mechanism that allows for sneaking a cup during brewing what happens is the pot slides outward to the edge of the warming plate.  This disengages the lever and closes the drip valve - as though you had pulled the pot to get a cup during brewing.
    The solution is to attach a pad with adhesive glue or a screw to the plastic lever.  Use a pad that can take the heat of the coffee pot.  I used a felt pad about 3/8" thick.  This allowed the lever to be in the open position even when the pot slides forward to the edge of the warming plate.  If you want to get a cup during brewing you can still pull the pot.   The lever will slide outward and stop the drip.  When you slide the pot back in, the felt pad allows the valve to open again.  Kind of a weird fix but it works.
    Problem Solver:
  • 19 Answers
You have to make sure the carafe is pushed all the way in because the mechanism that opens and closes the outlet to allow you to sneak a cup is in the back wall of the unit and if the carafe is not all the way in, it will remain closed and not let any coffee flow into the carafe and eventually overflow the filter. I also had a problem when I used finely ground coffee and used the metal filter as the metal filter would actually become clogged and eventually spilled over the top, so I just stopped using the metal filter and switched to the old fashioned brown paper ones and the coffee brews fine with no spills in nearly a year now.
Posted on May 29, 2008
Doesnt matter what filters we use this coffee maker is dumping coffee and grounds everywhere
Posted on Dec 28, 2007
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
Just purchased a PSTX series coffee maker. It is really fast and has the SS carafe. My question is, does it have a warmer or does it just rely on the SS to keep the coffee warm?
No in the BVMC-PSTX90 or 95 series.
If this is your model, Is a good coffee maker.
If you are NOT drinking your fresh brewed coffee withing 25 min. YOU DON'T WANT a warmer/burner.
And the reason why, IT BURNS the coffee. You don't have this problem with the "thermal Carafe".
Jan 11, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
We recently purchased a refurbished Cuisinart DGB-600 Coffee Maker at a yard sale. So far, we've had three batches of horrible coffee that tastes more like water with coffee flavoring. The first two...
It sounds like the water isn't flowing through the coffee grounds correctly. Perhaps you don't have the right kind of filter installed (either the right-sized paper filter, or the "gold" filter that comes with the machine) ... or, if uising pre-ground coffee, and if the coffee is all in a pile in the middle of the basket... the water will follow the path of least resistance, so much of it may run "downhill" and around the coffee, through the filter and into the carafe, without passing through the coffee. (That would be more likely if you're brewing only a few cups rather than a full pot.) Or, you might not be using enough coffee; I would use about 7-8 tablespoons of ground coffee for 10 cups of water. I'd recommend getting it working properly with pre-ground coffee before trying the grinder. It's also important that the lid of the carafe is in place while brewing, and that the carafe is fully seated in its chamber; the bump on top of the carafe's lid triggers a spring-loaded mechansim on the bottom of the basket, which regulates the flow of water into the carafe... so if any parts of this system aren't lined-up right, you may get unexpected results (including, in some cases, water all over the countertop).
I also recall, once upon a time, using one of those pre-packaged "packets" of coffee... sort-of like a large tea bag full of coffee grounds... and getting unsatisfactory results; again, the water found it easier to run over/around the coffee packet, rather than through it.
Oct 10, 2010 | Cuisinart DGB-600 Coffee Maker
Coffee spilling out the sides of the carafe
I had a Mr Coffee that did that. It was running across the brew pause arm and making a mess. I discovered that the position of the carafe had a lot to do with it. If I brewed with the handle pointing out towards me, very little leaked out. I finally tore the brew pause arm off of the bottom of the brew basket. I works great and hey, I can wait ten minutes for a cup of coffee! However, if yours is new and doing this, I would contact the company and see if they'll make it good.
Jan 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
My coffee maker, Cuisinart dcc 1400 only boils water, does not make coffee. It is one week old. I have a water filter in the plastic filter holder filled with coffee.
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 10, 2009 | Cuisinart Coffee Makers & Espresso...
Lately whether I put in pre-ground beans or whole beans, 1/2 the pot while dripping, leaks all over the counter, Help!
If water is leaking from the very bottom of the machine, your unit is broke and you need to call Cuisinart. If it is just overflowing the caraffe/basket:
Aug 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I clean it everynight but it still leaks coffee grins and coffee all over the place...this is the second coffee maker of its kind that i have had and they both have done the same thing. This only happens...
Jul 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee leaks all over the counter every time coffee is made. coffee appears to be coming out of bottom of machine Coffee pot lid is on correctly.
I had this problem after about a year of use. The thermal carafe lid had become clogged enough with coffee sludge (fine grounds/oil) and hard water deposits to slow the flow through the lid. I soaked the lid in a bowl of 2 cups hot soapy water + 2/3 cup white vinegar for a few hours, agitating the lid in the mixture every 1/2 hour or so.
Then, I rinsed the lid and packed baking soda in every opening and dropped it back into the mixture - hoping the fizzing action of the baking soda+vinegar would help loosen any remaining sludge.
I rinsed it again, and whacked it against the side of the sink for a final effort to loosen sludge. Repeated the baking soda + rinse + whacking a couple of times. No more problems.
In the future, I plan to do the soak at every Cleaning cycle/every couple of months.
Or, if you don't want to deal with it, replacement thermal carafe lids are available from Cuisinart for $6 + shipping.
Jul 29, 2009 | Cuisinart DCC-1200 Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Need to replace water carafe to Starbucks Barista Araoma 12-Cup Coffee Pot
I have the same problem, but have not been able to find a new carafe, so far.
Jun 10, 2008 | Starbucks Barista Quattro Coffee Maker
KitchenAid KCM511 Coffee Maker Logo
357 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Carmen Mikulic
Steve Allison
Steve Allison
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
