Question about Archos 704 WiFi Digital Media Player
How to connect to nbg334w
My archos704 is asking for a 10 digit wep key when my code is only 5
    Problem Solver:
  • 13 Answers
Change the WEP mode on the Archos to 64 bit, it sounds like you have different modes set.
Posted on Jul 24, 2009
I need a wep key
A WEP key is a Wireless Network security key that allows your devices to connect to the Wireless network. It is usually a 10 digit code (alpha numeric) that is set on your Network DSL router. If you turn your router upside down, you can find it printed with a barcode on a sticker attached to the router.
See if this works before we get to a more complicated answer
Sep 11, 2012 | Video Game Consoles & Games
How do i find the wep key number
You maybe having problem connecting wirelessly. There's a possibility that when you try to connect wirelessly,it's asking for the network key or WEP key, There are two option both free and paid depending on the warranty of the router. If the router is not under warranty anymore and you contact the manufacturer of the router to ask them to provide you the WEP key, they will ask you to pay for the support. But if you want the free one, follow these steps:
1. Check for the manufacturer sticker at the bottom of the router. You will see there a label that says WEP KEY. It's usually 10 digits characters.
2. Try to type that to the box where its asking for the security key for the wireless network.
3. If nothing happens and its says, INVALID KEY. There's a possibility that the router is manually configured and needs to be reset to the factory default.
4. Look for the reset button at the back of the router,usually a red hole that needs a pen or any pointed object to push through.
5. Push the reset button for 30 seconds while the router is on.
6. Power down the router for 30 seconds then turn it back on.
7. Try to use the WEP KEY that is underneath the router again since it already goes back to its default settings.
If its still the same, you will really need to contact the manufacturer of your Internet Service Provider to reconfigure the router.
Hope this will help...Thank you for using Fixya...
Feb 18, 2011 | NetGear Computers & Internet
Informed WEP key is a 10 digit number. could 231408&sid nos. & characters be my WEP key?
A WEP key is a security code used on some Wi-Fi networks.A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F.
The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
WEP keys are chosen by a network administrator, it would have been provided by the Internet Service providers, Hence it can't be as what you stated.
Oct 30, 2010 | Computers & Internet
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Aug 02, 2010 | Computers & Internet
Linksys router, I do not know my own wep code to
1. Step 1
Open your web browser, type " " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 30, 2010 | Linksys Wireless-G WRT54G Router
Setting for wireless d- link router for my laptop
WEP key is usually found on the back of the router or the side of the box the router came in. When the router is connected and you see there is a signal by the LED lights, click on the internet connection icon on the lower right of your screen. Select the proper wireless device to which you wish to connect. It will tell you that you need a WEP key. Enter the 10 digit code on the back of the router. If it asks for a 12 digit code, simply add two zeros to the beginning of the WEP key. Hope this helps!
Jan 12, 2010 | Acer TravelMate 4000LCi Notebook
My archos 605 gen 5 cannot connect to internect
Try:- Menu Settings Language and Region WiFi Region.....set to "EUROPE" Followed by: Menu WiFi Status WIFi ...important that pasword format corresponds to that of your WiFI system eg WEP or WPA. The type of format will dictate the length of code. Generally WPA can accept a longer code than WEP format although a short code can be used for either. If your Archos is set to WEP and your WiFi network set to WPA (or vice versa) the format conflict will not allow the correct password to recognised It should be possible to use the
Dec 30, 2009 | Archos 605 WiFi Digital Media Player
Where do I find my WEP key
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address,, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your change
Nov 21, 2009 | Linksys Wireless-G WRT54GS Router...
WEP key for 2wire 2700
The WEP number is in a wireless router near you, you must have a wireless router been setup in your home, then you have to program it. you choose your wep key code and only will have access to this wireless network.
contact your local IT or computer repair guy to help you with this process.
Jun 13, 2008 | 2wire 2700HG-B Router (2700HGB)
How to connect my palm to my computer when I am using a reseault Linksys
hi. try this.
have the tx search for you network using the wifi button at the bottom of the screen.
select/highlight your network and click edit. note do not connect to it yet
click configure.
on the security, pull down the arrow and pick WEP (or WPA according to what your router has.) note that since you mentioned the 10 digit alphanumeric code i assume it is WEP
on the key type click on 40 bit hex
i usually leave the four keys unchecked. (unless you have 4 keys)
insert your alphanumeric key that you use to protect your network into the dotted line.
click yes to connect. enjoy.
if your pda has connected and you still cannot get your internet, please read below.
PS. some internet servers may require a new user to input a name and password as a safeguard. this is familiar when you try to log into a public wifi hotspot with your laptop and the web browser always redirects you to an agreement page.
if this is so, what i do is to run my internet browser. let it load the first page then i accept the agreement and i am in.
hope this works for you. please feel free to email me with any more questions.
Sep 29, 2007 | Palm TX Handheld
Archos 704 WiFi Digital Media Player Logo
47 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
