Question about Acer Aspire L100 PC Desktop
Acer launch
Program just keeps running cant get any further this is initail setup
  • Anonymous Mar 28, 2008
    yup same problem need a solution
  • 128 Answers
Kill Startup:
1. Reboot and keep hitting F8
2. Choose SAFE MODE and hit enter
3. Win Xp - Start - Run - MSCONFIG or if Vista Click Start - then in Start Search Box type is SYS and click System Configuration
4. Click on Startup Tab
5. Click Disable All
6. Click OK
7. Click Restart
Posted on Feb 02, 2008
Sounds a bit simplistic, but I had the same problem with my Aspire 5315. Check hardware before software. My solution was to fix a stuck "Empower Tech" button! My laptop has a small green button in the top right corner of the keyboard. (It doesn't look like a button, but more like a stick-on logo!) It was constantly engaging the Launch program.
Posted on Apr 25, 2008
    Genius:
  • 1,226 Answers
Ok:
Try to examine installation disk, clean it very well.
if not work;
try use another CD/DVD rom and use your installation disk.
if not work, maybe your HDD drive committed problem.
in this case notify me for further instruction.
Posted on Dec 28, 2007
Kav60 factory settings
RTM - Read The Manual
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and search them for Factory Settings or System Recovery.Also I thought Acer supplied something in the Program List or Control Panel that was called eRecovery. if so launch it. Click Start/Programs and look for eRecovery. if it's not in the program list click Start/Control Panel and look for eRecovery.I found the excerpt below in the manual online.Launching Acer eRecovery Management
1 You may also launch Acer eRecovery Management by running the program
from the Acer Empowering Technology program group in the Start menu,
Apr 21, 2012 | eMachines Computers & Internet
Hi my acer aspire 5315 e button at the top dose not work so do you now who to fix this
Hello reeceman1,
The Acer Launch Manager needs to be running for the 'e' key to work. To run the Acer Launch manager, do these 3 steps:
* Click the windows start button (bottom left-hand corner) * Click All Programs * Click 'Launch Manager'
When the Launch manager window displays on the screen, click OK. Now Press the 'e' button and it will launch the Acer Empowering Technology
If this solution is helpful please click a thumbs-up rating.
Have a great day, martyshaw152
Apr 09, 2011 | Acer Aspire 5315 Notebook
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
There is a little macro button on my computer how do i change it?
Dear friend symbol (P) is your programmable key. By press that key you can launch a program instantly.
Now you are thinking how its function or else right?
Ok follow these.
1. Click Start > all program >Launch Manager.
2. Select the bar with is mentioned ( P).
3. Now press ADD >brows a file from your computer
select that and then press OK.( For example:
Microsoft office )
4. Now click ok in Launch Manager.
5. Now its ready to use. Press P key and you will
find the selected program start running.
Hope you understand now. If any further quarry then ask me. I am waiting for your reply. Thanks.
Feb 05, 2010 | Acer Aspire 5536-5224 Notebook
Fn f5 not working and volume bars not showing when pressing fn up/down keys
Acer management software not loaded. Doa system restore to a day before the problem started. If still no good, alt+F10 at boot time to restore it to factory condition. Back up important files first, as this will wipe the c: drive....
let me know if this works or not.
Jul 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer 5920 keyboard setup
there is a software that launch menager. the program controls the keys you talked bout. you need to remove LAUNCh MENAGER.
May 30, 2009 | Acer Computers & Internet
In acer 5920, acer arcade installed, can not be started by hotkey
You configure the keys from the Acer Launch Manager. If you go to Start, All Programs,  Acer System you will find the manual telling you exactly how to configure it.
Dec 10, 2008 | Acer Aspire 5920-6727 Notebook
My CineDash Media Console will not work anymore. The volume, stop, play, etc. does not work. Not with itunes anymore.
This is the way to get it to work!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager here (hosted here) or go to the acer site and find it there. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Nov 06, 2008 | Computers & Internet
My cineDash media console has stopped working
Confirm that this solution work very well. Thank you.
Jul 07, 2008 | Audio Players & Recorders
Acer Launch tutorial keeps running
have you tried running thru the tutorial?
Feb 13, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire L100 PC Desktop Logo
185 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
