I have been using the mp3 player for a while, works great. When I put a 1gb memory card in, downloaded music successfully, but I can not get the music to play that is on the memory card.
I haven't tried this, but I see no reason it why it shouldn't work. I have used an 2gb expansion card in my Sansa and it works just fine. The only problem is it will only play music off of an SD card, no video. I guess this is only to much memory if you don't need it. Rough guess is that a 4gb will hold roughly 1000 songs. I would only go for the smaller sd card if there was a substantial price difference and you won't be needing the extra space.
I'm confused. Are you saying that you can't play files on the SD card from the computer itself? Or, the songs won't play on the mp3 player once the SD card is loaded into the mp3 player?
First, make sure the songs are in the right format - each mp3 player will only play files of a certain type. Your best bet is to only use Mp3 format files -everything else is going to give you one problem or another.
Second, there is a size limit to what type of SD card the mp3 player can read. 2GB SD cards are the absolute maximum that this player will handle, and probably only 1GB even.
It is easier to get a SD memory card for it. Drag and drop the music onto the window which represents the SD memory card and then just put the SD memory card into the GPX MP3 player. I have the same MP3 player and it works nice... it was a good deal for the money! Take the savings and invest in a cheap SD memory card and you will be happy.... I was!
:-) Good Luck!
It is easier to get a SD memory card for it. Drag and drop the music onto the window which represents the SD memory card and then just put the SD memory card into the GPX MP3 player. I have the same MP3 player and it works nice... it was a good deal for the money! Take the savings and invest in a cheap SD memory card and you will be happy.... I was! :-) Good Luck!
you cant expect all mp3 players to play as many songs as u wnt. each mp3 player has a limit of memory card that needs to be attached. see whats the maximum memory your mp3 player can support. and also see if you can locate all the songs when the SD card is connected to your computer
help
