Question about Acer Aspire T310 PC Desktop
Power Hi there my ps has started blowing fuse in plug top whilst booting up, then it will be ok for 3or 4 days could this be a cpu cooling fan fault. Regards Roy Garner
  • 417 Answers
Ive never had this fault but it could be possible. My first reaction is to swap the Power supply unit. or simply just check that the voltage is set correctly for your country. if UK 240v if US 110v little slide on back of power supply unit. Try plugging the power cord into a different socket first though my be you electricity socket at fault.
Hope this is some help
J
Posted on Dec 27, 2007
Cooling fan is ok by cpu so cool
Still could be bad power supply even though the cooling fan is working. Recommend replacing the ps first since they are fairly cheap. If that does not work then the CPU is bad and needs to be replaced
Jul 04, 2016 | Gigabyte GA-G41M-ES2L Motherboard
Acer Aspire M5640 not booting up
Sounds like the GPU is faulty.
Feb 01, 2014 | Acer Computers & Internet
Laptop crashed
Really need more information, but my guess is dirty fan. If fan is blocked by dust, it may make noise and may run at high speed all the time because the CPU is overheating. If CPU gets hot enough, the laptop will shut itself down without warning. If dust is the problem, get some canned air. Before blowing into the air vents, try to spot where the CPU fan is and gently insert a toothpick to block the fan and prevent it from turning. A long blast of compressed air can spin the fan too fast and burn out its delicate bearings. Blow air from underneath and also from the side vent until air blows clear. In some bad cases of dust, the bottom or top cover must be removed to get it all out.
Sep 25, 2013 | Dell Vostro Computers & Internet
Laptop crasc. no error report
Maybe it is overheating and it shuts down so that it does not damage the motherboard.
Three things that will cause a laptop to overheat.
1) Dust - Dust inside the computer, dust clogging the vents, dust around the fans, cpu and heat sink. Remedy - The best remedy is to take the laptop apart and blow the dust out with a can of compressed air. If you don't take it apart you could blow out the vents with a can of compressed air and it might work, but you will be blowing the dust inside.
2) A Fan not working. The laptop will have to be taken apart to replace the fan.
3) The Thermal Paste around the heat sink and cpu had dried up or is too thin to keep the unit cool. Take the laptop apart and apply a fresh coat of thermal paste around the cpu and heat sink.
One sure sign of overheating is that if you immediately try to power the laptop back up, it will not boot. But if you wait awhile and let it cool off then try to boot it up, you can boot successfully until it gets hot and shuts off.
You could also try a Cooling Pad that plugs into the usb port and the laptop sits on it. It has fans to keep the laptop cool. The pad can be purchased for under $20. Try Tiger Direct at:
http://www.tigerdirect.com
When the site comes up just type in the search box at the top: Laptop Cooling Pad. When the search results come back sort them by Price Low to High and you will see them starting at $5.99 or so.
I like the one below for $12.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1879782&CatId=3486
May 08, 2012 | Computers & Internet
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
Hi, My notebook is Hp presario cq series While i start the machine the cooling fan is not revolving and i hear some error message regarding the seriousness of the fan problem, A couple of days back...
Compaq notbook Presario 1626 is now officially retired at HP
https://support.hp.com/us-en/retired-products
beep codes, count them report them>>?
how to fix something but but dont touch it>? the is impossible
think that trough?>
most pcs pack in lent every year, its needs service
if not up do doing that your self, try a shop?
the fan must blow and keep the CPU cool or it overheats and fails
the CPU will shut its self down, if it overheats. ending all things..
until its cleaned fully.
google or you tube this. act.
hp forum is here.,
https://h30434.www3.hp.com/
Jul 17, 2017 | Compaq Presario 1626 Cooling Fan Case...
When i boot up the laptop i get a message 'Main Fan Error' the fan runs on start up then stops just before i get the error message. Fan will not restart... Joseph
This message means that the fan on your CPU (processor) is failing or has failed. This is not good because if the fan on the CPU fails your CPU will overheat and cause your machine to lock up and become non-functional till it cools down and then the same cycle will repeat till the fan is replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 11, 2010 | Gateway (8008625) Cooling Fan, Heatsink...
Hipro HP-d3057f3r computer power supply broken?
I have the same problem. I found this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph06788&product=12455#bph06788_section_2
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
  • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
  • Aug 16, 2009 | Hi-Pro Computers & Internet
    ASUS cpu fan enquiry
    Hi, your motherboard type dont show up on google, but its the same as the CPU, if the cpu is skt A then heatsink & fan will be for a SKT A. Same scenario if its ,775,754,939,478 etc
    Have a nice christmas
    John
    Ps should only cost about £10
    Dec 13, 2007 | ASUS (CRUXK8MH7S) CPU Cooling Kit, Cooling...
    Pc is not starting up
    I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
    Aug 18, 2007 | Intel Pentium 4 1.7G, 1.7 GHz...
    Acer Aspire T310 PC Desktop Logo
    54 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
