Question about Radio Communications
Yaesu 800DXA I have a Yaesu G-800DXA rotator that still works but it has suddenly started to act up when I press the button for it to go right it does and then suddenly it will go back to the left while I am still holding the button down also it does this going the other way as well I have checked all the wires etc and all are good it doesn't do it every time just every now and then can someone tell me what is going on Thanks
    Problem Solver:
  • 7 Answers
May be button holding spring wear tear
Posted on Jan 13, 2008
Is there a secret button combination to hard reset Yaesu FT270?
So you used the power on MONI depress/ channel F4 method to reset the unit and it did not work?
Dec 12, 2015 | Yaesu Ft-270r 5 Watt Waterproof Vhf Two...
Eeprom error ? B0003 on display
if a reset has failed, these means either the eprom or the cpu is damaged.
Feb 11, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Yaesu support
have you tried a diode in the power supply rectifier? Re: Jeff
Sep 26, 2013 | Yaesu FT-990 DC Transceiver
Rotate screen back to horizotal
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
or
Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen.
Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't,
Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
hope this helps
Jul 25, 2012 | HP Pavilion tx1000z Notebook
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    My HP 6530 laptop (two weeks old) has suddenly gone to an inverted display and I can't seem t o get it right side up - do you know the Vista command to invert the display? Ctrl-Alt-Up/Down arrow does not...
    --Press the Ctrl and Alt keys together then either the up or down or right or left arrow key to rotate the screen.
    --if it's a GeForce Vid card, open your display settings (settings > advanced), click the Geforce XXXX tab, open 'additional properties', find NVrotate and click the button 'restore defaults' which is 'landscape (0 degree rotation)'.
    Jun 21, 2010 | HP Compaq 6530b Notebook PC
    My laptop screen is rotated 90 degress. how do I switch so its correct?
    1 Press Ctrl + Alt + arrow (left, right, up or down) to rotate the screen.
  • Step 2 Press the hotkeys and arrow keys until you have the desired rotation. This works with most video drivers on Windows XP. If this doesn't work, proceed to Step 3.
  • Step 3 Click "Start," then "Control Panel," "Display," the "Setting" tab, and then the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
  • Mar 23, 2010 | Toshiba Satellite A105 Notebook
    Yaesu Ft-50 hard to turn on
    The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
    I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
    I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
    The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
    Good luck, and 73
    DE NøAWN
    Mar 17, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
    Sph-m500
    Press the long button on the right side of the phone.
    Nov 05, 2007 | Samsung SPH-M500 Cellular Phone
    Radio Communications Logo
    122 people viewed this question
    Top Radio Communications Experts
    Steve
    Marvin
    Marvin
    Are you a Radio Communication Expert? Answer questions, earn points and help others
