It sounds like a typical loading error which would point to 2 main issues. 1. your disc is either dirty or scratched. 2. Your laser is out of alignment and needs to be tuned or replaced
Typically it is the disc that is at fault.
Try to troubleshoot by doing the following.
1. Try another disc. Preferably a new disc as then you can be absolutely sure that the disc is not scratched. 2. Try unplugging all the cables and then plug them back in again making sure they are all firm
If
there is still no joy after this it is still possible that your AV
connection is damaged. This is rare so if you can get hold of another
set of working AV leads that is ideal. Maybe take your unit into the
store with your game and see if they can try another set of AV leads
with your game, or try your game in their machine.
If you cant
get to a store and the first 2 options did not solve the issue you may
need to send your unit in to get the laser aligned or replaced.
the PS3 laser has two wavelegths at 405nm(bluelight) and 750nm (redlight). the highpower lower wavelength diode on your machine im afraid has failed. The bluray light reads bluray games and bluray dvd's. the lower power red light reads audio cds and regular dvds/dvdrs. you need to install a new laser ..only 100 i charge or 160 from sony (150+TAX+2 week wait+frustration from not playing COD4..lol) Now if you have the newer model laser KES410ACA, then you have 2 SEPARATE light sources...these tend not to fail as often. it costs the same to fix
If you want to solve soon the xbox360 problems like 2red lights problem, 3red rings problem,E74 error,audio but no video, audio but no picture, 3flashing red ring problem, red ring of death problem, rrod, ring of death problem, Disc read error, One red light problem, freeing problem, then you should have to Click Here.
Did you get the disc or the console fixed. If it gives u the error saying please insert this disc ito an xbox 360 console, then blow on it and clean everything.
If its a dif error tell me. I no how to fix a couple red-ring problems.
