Question about Bosch Washing Machines
Spots of Grey lint left on clothes after washing
Everytime I do a new load in my machine, the clothes and linen are dirtier than when they went in. They are covered in small spots of grey lint. I can see it floating around in the water when the machine is full of water and the drum is turning. I ran a few cycles on the hottest cycle with nothing in the machine, but even more grey stuff seems to be coming out. Is there a filter that could be dirty, or is it a blockage with the pipe? The grey stuff seems to be coming in with the clean water. My machine is a Bosch Maxx WFL2061
    Master:
  • 347 Answers
Have you cleaned the filter on the front bottom of the machine?
Posted on May 11, 2017
2 Suggested Answers
SOURCE: bosch maxx classic have cleaned filter front
how to clean the rubber around the door of front loader gets black dirt
Posted on Feb 12, 2011
Kenmoore 600 washing machine. Clothes comes out with brown spots.
Are you on a well, or town water supply? If machine needs cleaning you could try running a load with just water and a bottle of CLR it is a cleaner for calcium, lime and rust I think, if it smells after that of the cleaner run a load with white vinegar in it with the water. hope it helps, good luck
Jul 03, 2017 | Washing Machines
My clothes are coming out dirty with lint build up from the washing machine- kelvinator smart drive 053, have undone and cleaned centre- is there a trap underneath anywhere that may be full or blocked?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature according to soil type. For example, blood and mud are better washed in cold water, while sweat and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for the load can increase linting as there will not be enough detergent to hold the lint in suspension. Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times may not let the detergent dissolve properly. In these cases pre-dissolve the detergent. Overdosing of detergent can also cause residue when foam breaks down and will show as white specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Sep 18, 2013 | Fisher Washing Machines
How do I remove crud from inside a washing machine?
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
12.2 Soiling
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
soft water.
12.3 Linting
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
12.5 Black Marks on Clothes
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
12.6 Grey Marks on Clothes
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
12.8 Tangling
other. Do not load SmartDrive by wrapping clothes around the agitator.
Dec 19, 2012 | Fisher and Paykel Washing Machines
How do you clean **** buildup in a top load washer?
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
Dec 03, 2012 | Fisher and Paykel Washing Machines
Fisher Paykell washer left black grease spots on some clothes
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
Dirt after washing
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Aug 11, 2012 | Fisher and Paykel Washing Machines
How do I clean gw711 lint filter
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
9.1 Creasing
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
9.2 Soiling
than soft water.
9.3
Linting
9.7 Dye Transfer
9.8 Tangling
Jul 09, 2012 | Fisher and Paykel Washing Machines
The problem is the wash comes out with brown flecks all over it. I have taken out the agitator and cleaned it, this hasn't changed the result, still brown flecks all over wash
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
Jun 14, 2012 | Fisher and Paykel IWL12 Top Load Washer
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
Kenmore top loading washer -- deposits lint or fine dust on the clothes so that they come out dirtier than when they went in.
Remove the hoses from the pump and inspect the lint trap (inlet strainer) for build-up.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 24, 2009 | Kenmore Washing Machines
Washing Machines Logo
201 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
