Question about Sewing Machines
Singer 301a sewing maching
I have a singer 301a sewing machine, I just started learning to sew. I got a bunch of thread behind the shuttle and could not get it out with tweezers. I took the shuttle and bobbin holder out of the machine to remove the thread.
Now when I try to sew it draws the thread down into the needle hole? What do I need to do to fix it?
Thank You
Carl A. Brady
  • carlab504 Dec 27, 2007
    I figured that was what I would have to do, retime it.
  • ellen11 May 22, 2008
    I can't get my singer to rewind the bobbin
  • 106 Answers
SOURCE: Singer 7422 bobbin thread bunching up
I assume you checked to see there are no needle bits in the bobbin case holder.
Without looking at the machine it is difficult to diagnose the problem. It could be any one or a combination of problems, timing, needle bar height, damage to the hook and base etc.
I strongly suggest you have it looked at by a sewing machine tech.
Posted on Mar 29, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 69 Answers
SOURCE: singer 301A stitch jam
It sounds like your feed pressure and tension are both off. Try sewing with out thread. If the fabric goes all over the place, you need to adjust the feed pressure (the screw on the top of the machine). Tighten it down until your fabric feeds evenly. If the fabric is bogging and not feeding, you need to loosen it.
Your tension sounds like it is off as well. Make sure it is set around 2-3 and check your tension disc, make sure there is no thread in between the disc. If so, remove it. Now, thread the machine and check the thread through the needle. It should pull out quickly and smoothly. Now, put the presser foot in the down position and pull the thread, it should have some resistance. If not, your tension is set too low. Turn it up a little and try sewing. If the thread is still knotting up, you can turn the tension up to about 5, if that does not correct the problem, you will need to adjust the tension dial itself. To do this, press on the numbered part of the dial and it will push in, then turn it to a lower number, release and make sure it has locked back into place. Then adjust again as I previously instructed.
Posted on Feb 07, 2009
Mongo32
  • 111 Answers
your machine threads from right to left. the needle flat spot faces left. big loopy things means that the upper part of the machine is not threaded properly. as far as the needle hitting the bobbin case, it sounds as if someone removed the hook (part that holds the case) and put it back on 180 degrees off.
Posted on Jun 01, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
Singer sewing machine 534 Machine and bobbin are threaded - won' sew
A few things you can check are.
1. is the needle the right one for the machine?
2. is the needle properly inserted and oriented correctly for the machine?
3. Is the bobbin inserted correctly, so it unspools correctly for the machine?
If that all looks right, then take the needle plate off and watch the shuttle hook. It should be very close to the needle when the needle is at its bottom most part of the stroke. If it is well behind, your machine\'s timing is retarded. You\'ll need to take it in for adjustment.
Apr 13, 2013 | Singer Sewing Machines
I have a singer sewing machine model # 758 touch n sew and I cannot find how to set the bobbin thread tention. The thread bunches up under the bottom plate and adjusting the upper thread tention does not...
Hi, welcome to fixya, maybe I can be of some help
I checked on singer website & they have a free downloadable instruction manual in PDF form just follow the these steps
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 758 )& click search
the second one is free
Sep 10, 2011 | Singer Sewing Machines
My machine bunches thread at bottom of material and is runnung sllooow. I am not sure where to oil it. But do have sewing machine oil. It's like brand new, but got it like 8 years ago. Please help...
You can go to www.singerco.com and buy a manual for $15. right from Singer. You really need your manual to learn where to oil your machine and other tips. Singer's site does have some things about threading your machine, because your problem is in your top threading. You can also call Singer at 1-800-4singer. Good luck
Oct 26, 2010 | Singer 1116 Mechanical Sewing Machine
Singer 301a that picks up thread on the wrong side
Make sure the flat side of the needle is facing back.
Jan 29, 2010 | Singer Sewing Machines
Singer 301A needle breaks
do you have a book, refer to threading. This machine threads differently than most, threads like a 221 featherweight. Needle goes in backwards, and threads backwards. in wrong and you can have problems, also threading can cause your problem if you have missed tension or a thread guide. great little machine
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer 301A stitch jam
Singer Merritt 2430
Hi!
There could be several reasons due to which the thread keeps bunching up underneath.
It may be due to tangling of upper thread. Remove the thread completely from the machine, use correct size spool cap for the size of the thread spool, re-thread the machine, now remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please rate the solution as FixYa and revert for any clarification.
Thanks
Rylee
Apr 23, 2009 | Janome 6019QC Mechanical Sewing Machine
Feb 06, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
133 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
