Pc Ware M748LMRT Motherboard
Problem for Pc Ware M748LMRT Motherboard
VGA1 video adapter problem
By osmy on Dec 27, 2007
I have been trying to refurbish an old model pc (xcel-2000, pcchips M748LMRT) using a slot1 Pentium II processor @450MHz, but there is no way I can get the video adapter working, so that I can configure the BIOS settings. The manual for this mobo says it should used at least one pc-100 MHz SDRAM memory on slot 1 for the video to work, but I don't have a pc-100, instead I am using a 128 MB, pc-133 MHz memory, but the VGA1 video adapter (which is connected to the motherboard) does not work.
The manual for this motherboard can be downloaded from here:http://mldisplay.com.br/m748_v13.pdf.
Please, any help will be greatly appreciated,
Thanks in advance,
Osmany.
Same Problem
Feb 10, 2008
-   VGA1 video adapter problem-   Pov To
Feb 10, 2008
-   VGA1 video adapter problem-   Guest
Best Solution
posted on Dec 29, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Osmany,
The Problem could be that the BIOS setting for the shared video memory is set to "disabled". You can fix this by either 1) install a PCI video card temporarily and then making the change to the BIOS to shared memory "enabled" or 2) clear the BIOS settings using JP5 on the motherboard.
Hope this helps.
Paul
Solution #2
posted on Oct 26, 2009
Not Rated)
nish24
Rank: Apprentice
Rating: 0%, 0 votes
The MB supports both PC100 and PC133 RAM. Make sure the RAM Module uses LOW Density Chips (16Mx8) Technology. You wont get video or even be able to POST (Power-on self-test) with latest high density modules.
Was this helpful?
Yes
No
Solution #3
posted on Nov 19, 2008
Not Rated)
almasshahzad
Rank: Apprentice
Rating: 0%, 0 votes
I have M748LMRT motherboard which has Xcel2000 chipset. I want to know pinouts of ATX header J3
Was this helpful?
Yes
No
Solution #4
posted on Jul 01, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
make sure you have a PC100 memory chip in the DIMM #1 slot or it can't use that memory .
Your motherboard does not support PC133 memory.
Popular Solutions for Pc Ware M748LMRT Motherboard
Questions and Unsolved Problems for Pc Ware M748LMRT Motherboard
Do you recommend Pc Ware M748LMRT Motherboard?
Answer
Answer
Sir, I have a Intel 945GCM-S+ICH7 Chipsets Motherboard. I am facing a problem since from last 4... (More)
Answer
I don't know which poles to put the wires on from the power switch to my ices 003 b motherboard
Answer
i have a desktop dv9000, that have stopped connecting the monitor, i tried the monitor on my other... (More)
Answer
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the... (More)
Answer
how do i unlock channels on an ntl set top box?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pc Ware M748LMRT Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
