Apple iPod nano 4th Generation Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I pod nano not reconized by laptop with vista usb device not reconized code 10 appears
Anonymous
Level 2:
Scholar:
  • Expert 83 Answers
  • Posted on Jun 08, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
83
Questions
0
Helped
25817
Points
236
Which USB ports are you using? I just had this issue on a customer's computer and it turns out that a 5 port USB 2.0 hub they had installed in the pc wasn't functioning properly and so I would get a code 10 on their iPod nano. I plugged it into the onboard USB 1.0 ports and it installed correctly and synched. I would suggest trying other USB ports. If that doesn't work then go to Programs and Features in Control Panel and uninstall all apple products and then reboot and reinstall iTunes.
Enter code i pod \
Hi
Things You'll Need
iPod Nano Mac or PC computer iPod USB cable
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
My ipod nano 2g doesnt get recognized by vista anymore
Have you tried connecting it to different USB ports, go into your device manager and Select USB (bus i think it is), at this point have the pod disconnected. When you connect it at the top it gives you the option to refresh and see if their are any changes under USB. It could be a number of things, problem with the USB port, damaged cable, out dated drivers etc.
Rylan
I connected my i pod 2 the computer and it showed me a messagae saying error in usb device.and after that it got stuck i cant it switch it off and its not even getting detected by my laptop,the light keeps...
Try reseting the iPod.
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
-Logan
I pod only turns on then shuts down and comp doesnt reconize it
Your battery is dead!!! Try to recharge with USB adapter!!! If that doesn't work you need to change battery. Give me some spec. about your MP3!
2answers
Miissing e drive
Try updating or reinstalling iTunes.
Ipod nano 3rd gen
It's in disk mode and the computer thinks that it is only a storage device. You need to reset it to get it back to normal.
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
2answers
İpod nano not seen at explorer and itunes
- check the cable - check the connections on the bottom of the ipod for bent pins, or dirt - make sure ipod battery is fully charged - if you have all your library backed up, reset ipod to factory. You will lost all settings etc. though. - check usb ports are working properly with no conflicts or driver issues (control panel\system\hardware\device manager) - uninstall usb ports on pc, let pc redetect them
FRozen !pod
Hi cholo, -Turn the hold switch on and then off. -Hold down the menu and middle button until the Apple logo appears, usually about 6 to 10 seconds. -If that doesn?t work repeat the process and you should be good to go. -If that didn?t work try plugging you Nano into your computer using the USB cable Let us know if you have any more questions and please don?t forget to rate the posting.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
