Motherboard pluging problesm
My case came with a bucnh of cords for power lights fans so on and so forth i have a winfast mother board 6150BK8MC. I need someintrection in how to pluge these cords in or a basic manuel.
    Problem Solver:
  • 25 Answers
Refer to u'r mother board manual. Its there.. the guide ...pdf file..
Posted on Dec 28, 2007
Had my motherboard changed by local repair shop. Both fans are now running constantly & it is deafening, also power light no longer comes on and was told it was "no big deal". Have 2 like computers,...
Ok so what fans? the case fans? the cpu fan? The power supply fan should always run. The case fan can be wired to the mother board and do an speed step system (slow to fast) depending on heat, same with cpu fan. As for the power light its just an matter of pluging in the wire from frount panel to the mother board pins for pwrled. Asus has an download for your board to get the pin outs.
Feb 25, 2010 | ASUS A7S8X-MX Motherboard
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
  1. you will see the power supply fan turn. you power supply is in good order. replug the power supply, and test again.
  2. you will see the fan turn for a few second then stops. you power supply is selective, and may require a different type of motherboard. Get a new one.
  3. you wont see the fan turn at all. get a new one.
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
  1. 20 pin power cable.
  2. 4 pin 12 volt power cable (if applicable)
  3. speaker
  4. power switch
  5. power led
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
Aug 26, 2009 | Biostar I865GV-M4 (MB865GVM4) Motherboard
The purple light is flashing in the front and tries to start and won't turn on. disconnected power cord and held button in for thirty seconds still have same issue what could it be?
This can be a faulty power supply or a damaged mother board. here's how you can confirm.
When pressing the power button, inspect the cooling fan that is located on the back of the power unit where the power cord plugs in. if the fan starts then stops immediately, this will confirm a damaged power supply.
Now, if the fan continues to operate but, the CPU doesn't start to power up and load the OS, thsi will confirm a mother board issue. replace the mother board in this case.
Jun 21, 2009 | E-Machines T6216 (827103077834) PC Desktop
Problem getting hard drives to run
check the power supply. some time power supply not suppling the proper voltage to the accessories.
Nov 26, 2008 | Intel Motherboard
ASUS p4s533 will not start
Your motherboard is bad and will need to be replaced.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 08, 2008 | ASUS P4S533 Motherboard
My mother board
hi icebox143ph,
just insert ur proceesor in ur motherboard if processor fan is moving than the motherboard has minor defect i.e display problem if processor fan is not moving than the motherboard ic has burn
Mar 06, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Emachine T2958 will not turn on - has no power
Dear asksforhelp,
As u have told that u have change the power cord then the second thing u can try that check the SMPS is it working or not to check this u have to know that where is the SMPS where u pluged in the power cord in the cpu that thing is SMPS check wether the SMPS fan moving or not if no then u have to replace the SMPS if it is working then u have check wether the mother Board get the power supply or not check the 12 pin power connector insert it in mother Board if still it not working then it is definatly problem with u r Mother Board. So it is better for u that to go for New One.
Feb 13, 2008 | E-Machines (T2958) PC Desktop
Trying to put in a new Motherboard
Here is the link to the manual:
Here are the details:
This is located at #7 in the manual which if the CPU is Top-right, then this panel is in the bottom-left. Plug the three little plug on PW RBTN#, where the two wires in the plug lign up on the pins. Put the HDD LED and PLED LED power in the locations above. They aren't working, turn them around, it's pretty harmless.
Enjoy. Rate this a FixYa! please.
Dec 01, 2007 | Foxconn 6150BK8MC-KRSH Motherboard
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
