Question about Whirlpool LER5636P Electric Dryer
Whirlpool ler5636eq3 Dryer will not turn. heating element is on.
  • jwblackk Jan 10, 2008
    I checked the belt and it was fine, snug up against the drum. What is my next step??
  • drbock2 Apr 26, 2009
    I have a Whirlpool dryer, model LER5636EQ3. It will not start. The start/stop button on the right does not work. Is the problem the button or is there an inline fuse that's blown and needs replaced? I had a load of clothes actually drying when it stopped working.
My whirlpool LER5636EQ3 will not shut off. It does not matter if its on a timed dry or automatic dry. Any ideas?
Posted on Sep 14, 2010
  • 262 Answers
Check and see if belt is broke you have to lift the top and then remove the front with two screws on each side on the inside pull out and up. after you lift the top you will see the tub and a belt should be on it if so lift up on the belt it should be snug if it comes off in your hand bingo there is your culprit remove front and install new belt
Posted on Dec 29, 2007
2 Suggested Answers
  • 619 Answers
SOURCE: Whirlpool Dryer LER5636EQ3 will not heat
Betya missed the thermal cutoff. Located half way up heater canister above the t-stat. This is usually the cause.
Posted on Feb 13, 2010
HELLO THIS MORNING I HAVE A QUICK MY WHIRLPOOL MODLE#ler5636eq3 it stopped drying my clothes can you help me please
If everything works, timer, latching shut off the sensor , more likely its the heating element, easy to fix, the part won't cost you more then 100 bucks, good luck.
Jan 20, 2018 | Whirlpool Dryers
I have a whirlpool dryer model #LER5636EQ3 which the power cord was missing upon aquiring it, the wall socket in my laundry room is a 50amp, so I need to know if a 50amp power cord would be a proper...
The recommended power cord is a 30 amp 3- or 4- wire cable. A 50 A cord could cause a problem by allowing a surge to the dryer motor and damage the dryer or start a fire. There are 30A to 50A adapters (see RV and boat supply vendors). The installation instructions for the LER5636EQ3 are available here: . See page 5 of the PDF.
Note: the 50A outlet has a 50A circuit breaker protecting it. If you swap the outlet to a 30A outlet, you will also need to replace the breaker with a 30A one.
I hope this helps.
Feb 01, 2013 | Whirlpool Dryers
I have a Whirlpool electric dryer, model #LER5636EQ3. Several years ago, we replaced a part due ti the dryer not heating. It worked great, well a few years ago, the dryer began taking 2 cycles to get the...
Jun 23, 2017 | Dryers
Whirlpool Dryer Model LER5636EQ3. Runs for several minutes then stop.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 23, 2011 | Avanti D110 Electric Portable Dryer
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer LER5636EQ3 will not heat replaced heating element, jumped out all temp and heat fuses.
Feb 13, 2010 | Whirlpool LER5636P Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly.
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
I have a whirlpool dryer LER5636EQ3 that will shut off after 3-5 mins.
Go to and enter LER5636EQ3. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Whirlpool video that shows disassembly and identifies major parts.
May 18, 2017 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
754 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
