Does frequent partitioning and formatting spoil the Hard Disk?
Ive formatted my PC's Hard disk 5 times this month(Just trying to install Linux).
Ive got the correct partition of XP/Linux now.......and its running well........but did that cruelty affect the disk??
    Sergeant:
    Champion:
  • 243 Answers
No it will be fine honestly :)
Posted on Dec 29, 2007
Yesterday I buy a Samsung Laptop model R538 but with Linux Julia preinstaled. I want to change the OS with Win XP. I begin the instalation and at the point in which I know he want to format the disk I get...
Solution:
1. Boot into Linux.
2. Use "fdisk" command to delete "ext" partitions. // In fact, no need to use other tools (e.g. killdisk)
3. Run "fdisk" command as root.
4. For those who don't know how to use "fdisk", I provide an example here. (Read the man page of "fdisk" will be better)
//Remember !!! fdisk can format your hard disk (which will erase all your data), use it with great care -- unless you know what you are doing, otherwise don't use it. (I will not take any responsibility of my suggestion)
i) fdisk /dev/sda
.) For those who use PATA (Parallel IDE) : fdisk /dev/hda
.) For those who use second hard disk : fdisk /dev/sdb (2nd SATA hard disk), fdisk /dev/hdb (2nd PATA hard disk), fdisk /dev/sdc (3rd SATA hard disk) and so on ... {sd [a, b, c, d, ...]}
.) fdisk "what" depends on where your linux partition is.
ii) use "m" to read the available options
iii) press "d"
iv) press the number of the partition you want to delete
v) Remember ! if you don't want to make the change, press "q" at any time. (that means quit without saving)
vi) If you want to make the change, press "w" (that means write the change to hard disk)
5. There may sometimes cause a warning message say something about not synchronize the disk (because you cannot make changes while you are using the partition -- if you are booting the partition now), the change will occur after you shutdown and reboot the system.
6. Okay, you can reboot the system now and you will find that the partition is empty now.
7. You can install XP or what ever now.
** For those who cannot use "fdisk", my simplest suggestion is to re-install Linux if you don't have any other tools (such as killdisk). And then you should be able to use "fdisk". In fedora 8, you can even choose formatting the hard disk in "vfat" file system (which can be recognized by almost all computer include windows xp and so on -- see "File Allocation Table" wiki) during installation. Therefore, no need to run fdisk
May 31, 2017 | Hitachi Travelstar 5K500.B HTS545050B9A300...
Ive been trying to set up a new computer with an older family pc. It has windows xp home edition on it, but everytime i boot it up it doesnt go past the startup screen and says i need a start up file.
Check whether the hardware requirements of XP matches yours. If there is no problem, check for any error in the hard disk. You can use any of the bootable disk management tool. I recommend Hiren Boot CD or Knopix (linux) because both are free and easy to use. Format the disk partition to NTFS. And try installing Windows now. If still there is a problem then your XP cd maybe corrupted.
Sep 19, 2010 | Microsoft Windows XP Home Edition
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Nov 13, 2009 | Computers & Internet
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
How to Install both XP and Linux?
I would install XP 1st then Open suse or Ubuntu. When you install either of these linux OS's ensure you install to another partition other than the windows one. Both installation routines will allow you to format the drive to the linux ext2 format and automatically install a boot manager (usually GRUB) which will allow you to select the OS you wish to boot.
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Acquired an amilo pro ef6 with linux
your hard disk has been partitioned and formatted to reflect linux structure - if Linux is still working, there should be a facility to create a partition (FAT32 / NTFS) - DO THIS...With min of 5Gig.
Once partitioned - then install Windows . .you can then remove / format the linux partitions, and recover the lost space that the PC does not at the moment see.,
May 29, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Drivers required
SCSI Drivers are only an optional part.
This is not a problem with your driver floppies.
The problem is with the linux being preinstalled on the HD.
Linux uses many types of file-systems. Even if it was NTFS or FAT, it is most probable that windows xp cd won't be able to recognize it; because, it may use unsupported method of formatting.
What you have to do is;
1. Format the two HDs by either
  • Moving it to another windows or linux computer and fully formatting the Hard Disks using fat32 or NTFS (supported by windows). If it is a windows PC using for formatting, no problems. If it is a linux system, delete all partitions, and format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
  • By a linux installation CD and here too, format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
2. Install the windows xp in it, using the same booting from CD Porcess. Here, you may or may not choose to install the SCSI drivers ( the floppy you got by pressing F2 when it says to do so in the installation immediately). It is good not to install the SCSI drivers if it is not a necessity for you.
Now, you can create any number of partition, format, etc during win XP installation.
Feb 18, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
FAT32 format, how to do it in Windows XP?
Try using a third party program, like Norton Partition Magic, Acronis Disk Director Suite, or Paragon Partition Manager.
Nov 20, 2007 | Western Digital WDG1C2500N MyBook Premium...
Computers & Internet Logo
782 people viewed this question
Alun Cox
David Payne
David Payne
