Question about ASUS P4VP-MX Motherboard
Low or high density ram or both?
Sorry to disturb you, but anybody i know can answer my question about my motherboard and no notices are in the user guide that came with it.. Here is the problem. My motherboard is a p4v533-mx, and it came with a 512 mb DDR 184 Pin 333Mhz, Non ECC, UnBuffered , Non Parity, low density. Now i bought a 1 gb new card to increase my memory, but in the guide there is not it must be low density, so the one i got is 1 gb DDR 184 Pin 266Mhz, Non ECC, UnBuffered, Non Parity, high density. The question is: can they work together, i mean does my motherboard support them both at the same time? I hope you can answer soon, because if they don't work, i would try to give it back. I apologize for my bad english, i'm from Italy. Cristina
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
They have to be the same in pairs low ok jim
Posted on Nov 25, 2011
In my experience you can insert any memory module you like if it is the correct type but a high density or whatever will default to the lowest common denominator memory module as it is the arbiter of operating speed. I RECOMMEND YOU USE THE SAME MODULES AT ALL TIMES.
Posted on Feb 06, 2008
This is not the answer to my question.
The link you mention, says they both fit (read better), but i don't know if they can work together.
Thanks anyway.
Posted on Dec 29, 2007
    Problem Solver:
  • 8 Answers
Hi Chrisina,
Yes you have made an error in your purchase. Download a free memory checker here: to discover what memory you can install in your PC.
Good Luck,
Posted on Dec 28, 2007
Pc ddr memory what is the difference between high density and low density
you need to check with board to fine what ram works with first.i use what they say to use so no problems later and save money as well ok jim
Nov 25, 2011 | Computers & Internet
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
How much ram and what type
From the manufacturer's web-site:
download the User Guide (a PDF) and scroll-down to the SPECIFICATIONS section, to find the exact answers to your questions.
Aug 02, 2010 | ASUS P4S533-MX Motherboard
How can i know if a ram suits my Legend QDI
you got to options
1. following the indications of your motherboard documentation (recommended/best), if you need to find out details about your motherboard you can possibly download and use one of this tools to get info about your motherboard and possibly find the manual online in the manufacturer's website
2. the following page will check your system to find out what memory you have and what you need and up to how much you can go
3. checking on ebay: in the following links indicates that it should be low density:
Module Size: 512MB
168 pins
3.3 Volt
Structure: 64Mx64=512M
Low Density: 2 Banks of 32Mx8
CAS Latency: CL3
hope this helps
Nov 22, 2009 | QDI Group QDI Advance 10T Motherboard
Planning to upgrade my RAM(motherboard K7SOM + V7.5C). Ram have high & low density. What is the difference? Which suit my motherboard? Thanks.
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
Oct 22, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
ECS 648FX-A1 can it use high density memory?
The Motherboard limitation are DDR400 = 2GB maximum size per slot
Allthough you can with slower memory DDR333 or DDR266 go to the 3GB memory limit.
Due to the age it will be trail and error on the memory types. You won't necessary get any problems with the high density memory as long as it is good quality memory and you don't exceed the slot memory limit as mentioned above.
I recommend that you download the motherboard manual and read it.
Dec 02, 2017 | EliteGroup 648FX-A Motherboard
I tryed to restore my emachine w1800 with my restore disk and when I reboot a blue screen comes up a problem has been detected and windows has been shut down to prevent damage to your computer. If this is...
could be a couple of things, usually when you get the BSOD (blue screen of death) there is usually a ram problem, have you noticed your pc getting slow, sometimes the ram sticks break down over a period, try getting hold of a memory tester software and checking the PC, this is usually done through the inital start up before windows is loaded, please ensure though that if you need to get more ram that you use the correct one for your motherboard, buying incorrect ram can cause more problems and is a waste of money, is good for checking ram in pcs, also you need to make sure that if it says low density you use low density ram, or high density for high density. also make sure that you buy the one with the correct amount of pins.
hope that this helps
Feb 28, 2009 | E-Machines W1800 PC Desktop
Memory problems
If you are sure your motherboard can handle a 1 GB RAM stick, then the general answer is that the motherboard can not run High Density RAM stick as yours is possibly. You might need to exchange it for a stick of Low Density RAM.
According to some quick research, it says your motherboard can only read up to 2 GB TOTAL of RAM even if you have more installed.
Jan 27, 2009 | EliteGroup ECS K8T800-A (1.0) AMD K8...
K7vm3 mobo RAM
If you are referring to the ASROCK mobo then it will work on the high density although not as good as with the low density but it will nontheless work.
Oct 13, 2008 | VIA ASRock K7VM3 Socket A/...
Gigabyte GA-81EXW motherboard needs ram
If you plan on gaming then go for the higher priced and yes more ram will help in a gaming situation but if your just surfing and writing emails then no you don't need them,It's the timings that make ram better or not,all motherboards will do ok with cheaper ram but make sure you have the correct ram and install it in 1 and 3 or 2 and 4 they are usually colored the same
Oct 06, 2007 | Intel Motherboard
ASUS P4VP-MX Motherboard Logo
291 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
