Question about Refrigerators
Refrigerator buzzing I have a maytag refrigerator, about 4 years old. It started buzzing a good bit lately. It does it when it's trying to kick on. It doesn't do it every time, sometimes it starts just fine. But when it does do it, it may do it any where from 2 to 5 times before it will kick on. I was wondering if you could help me decide what the problem is, so that I can get the right part to fix it. Thanks.
    President:
  • 878 Answers
Serial, it sounds like your compressor windings are failing. This has a 5 year warranty on it. I've seen this may times. Call for warranty service and have them replace the compressor, Catriver.
Posted on Dec 27, 2007
Maytag side by side refrigerator - refrigerator and freezer both not cooling.
I had same issue , required a new compressor and regas. All cooling for fridge side is blown in from freezer
Jan 25, 2013 | Maytag Refrigerators
My 20 year old Maytag fridge has stopped cooling properly. It will cool the freezer to about -4 then warm to about +4 and continue to do this. What might the problem be? i
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Maytag Refrigerators
The freezer is defrosting and the refrigerator is warming. the compressor is kicking on approximately every three minutes and is making a loud buzzing sound when it kicks on. is my compressor shot?
Probably not. The compressors are very sturdy and long lasting. The compressor is controlled by a start relay, and is protected by a thermal overload. It sounds like your start relay is bad, which would explain the buzzing sound. It takes a certain amount of time to cool down, and then tries to start again. The start capacitor and start relay should be replaced.
Nov 21, 2010 | Maytag 15 Cu. Ft. Top Mount Refrigerator
My Maytag French Door refrigerator MCFC2061HES recently started making a buzzing noise. The refrigerator is 5 years old. What is the problems. Please tell me it is not the compressor.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 16, 2010 | Maytag MFC2061HES Stainless Steel French...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Every 2-3 minutes it sounds like something is trying to start and then the starter type switch stops, now freezer is starting to frost. It has been happening for about 3 weeks now but the starting noise...
Compressor problem. There are start components mounted on the side of the compressor, and should be removed and tested. The parts include the start relay, (start/run capacitor if it has one) and the overload switch.
To test these components you must have a working knowledge of electrical an use of a good VOM meter.
If not, remove the parts, and take them to an appliance parts house. They usually are happy to test them for you.
If they test O.K. you have a failed compressor.
P.S. If this machine is under 5 years old, the compressor is under warranty, (some have an extended 10 year warranty). if the warranty is in effect, do nothing. Call the dealer who would handle the warranty. You would have to pay for replacement of the start components, but having it serviced by an authorized warranty station will keep the balance of the compressor warranty in effect. Hope this helps... Jack
Oct 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Frig. is 5 years old - Not cooling - Buzzing clicking sound
Sounds like the compressor or start relay have went out.
For any recall info you would need to give the full model and serial to the Maytag.
jim
Jul 27, 2009 | Maytag MFD2560HES Bottom Freezer French...
REF AND FREEZER STOP COOLING
We had a repairman come out, said it was the compressor, bad news...$650 if he repaired...good news...compressor under manufacturer's warranty for five years so you may want to call Maytag. It will be less expensive if the part is covered and you only have to pay for labor. Hope this helps. Bought our fridge 12/2004 so it was covered.
Feb 03, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
190 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
