Do you have the service bulletin for this model from Toshiba? it shows all the caps--any cap can be used-original are surface mounted-but you can use traditional caps if you have enough room--also there is a company called PTS electronics who can rebuild the board for you---I HAVE THE SERVICE BULLETIN FROM TOSHIBA FOR THIS MODEL--SHOWS THE CAPS THAT NEED TO BE REPLACED ETC--BUT I have no way to provide my email address here (it is not permitted) IF you replace with conventional caps you need to be very careful not to damage the foil paths on the top of the board...
Remember--I have no way to email you the photos--Toshiba will not provide you with this information as it is restricted---
Caps are all with CX location number:
261,270,230,178,221,250,514,5030,241,541, and 670.
Let me know if I can help.....
SD TECH
Comments:
Oct 15, 2009
- Let me know if you got it clearly---heat is what gets these parts--I have a 1991 60 inch HItachi that I had to replace 14 caps in the DCU convergence memory board because of this type of thing--the fancier they make the plumbing the easier it is to block up the drain...... several Toshiba sets with this problem...
The Hitachi works perfect but I am not going to change the 30 surface mounted caps for the PIP as I don't use it---more surface mounted caps............
SD TECH
