Question about Garmin StreetPilot C330 GPS Receiver
Question my garmin street pilot  turned off suddenly for no reason and doesn't turn on even on connecting to the power source.
  • Anonymous Dec 29, 2007
    low battery signal yesterday
    today just shut off for no reason
    i removed the face plate and held down reset button for 3 sec.
    did not correct the problem
    low battery signal
    today it just turned off for no reason
    i removed the face plate and held down the reset button for 3 sec.
    no change
Pry off the screen bezel (the silver rim around the screen) using your fingernail in the slot under the top edge. Hold the reset button for three seconds. plug into power and go.
Posted on Dec 30, 2007
Hello:
I reset the device and it now works. You many want to try it
Posted on Dec 28, 2007
I have the same problem.... Please let me know if you find a solution.
praveen_pandey@hotmail.com
Garmin Street Pilot C330
Verify that you are getting 12 volts from where you're connecteing this device.
May 14, 2008 | Garmin StreetPilot C330 GPS Receiver
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
Garmin Street Pilot C330 - Produces Deafening Noise!
suddenly froze can not turn it off what to do thanx
Jul 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Gps - street pilot i5 garmin
try this first-if the unit has batteries installed, remove them so unit runs on power cord only
Jun 01, 2008 | Garmin StreetPilot i5 GPS Receiver
Garmin c330 street pilot
The lighter socket does it work. Because it to has a fuse. ck your car fuse box (mini fuse).
Oct 29, 2006 | Garmin nuvi 350 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
16 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
