Question about Broan-NuTone Allure® I WS136BC Kitchen Hood
Vibration at high speed
When i turn the fan at high speed it start vibrating
  • 38 Answers
Its the blade. Its either not balanced or loose on the shaft.
Part # R531067. I do service calls for Broan.
Inventex.com
Posted on Jun 14, 2008
  • 33 Answers
Check these causes fan blade brackets,fan blade for cracks, any grease on blades.
Posted on Jan 05, 2008
2002 GMC HD2500 8.1,when i turn the ac fan on high some thing in the dash vibrates,
Sounds like something fell down into the blower motor. You will have to remove blower motor and take a shop vac and run it thrue the vents.
Jun 27, 2017 | GMC Cars & Trucks
Vibration in drive train started in higher speeds, not vibrates at all speeds
check drive line "U" joints and cv joints for failure.
Jun 12, 2015 | Cars & Trucks
Loud buzzing noise
Is the vibration coming from the heatsink itself or from the fan running at high speed?
I highly doubt the processor itself is vibrating; no moving parts to vibate. A more likely suspect would be one or more of the fan blades having gone out of balance and causing it to resonate at certain RPMs.
What cooler are you using?
Increase Engine Horsepower.
Jun 02, 2012 | KLH ASW10-120 Subwoofer
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
A/C and heater raddle/vibration when fan control turned on
That vibration is caused by something lying in the fan. This causes an imbalance in the fan that gives off the vibration. You will have to remove the blower motor in order to get to the fan and clear the fan of whatever is stuck in the fan.
Oct 06, 2009 | 2004 Chevrolet TrailBlazer
1998 honda crv vibrates when starting out
Increased vibration from a vehicle indicates worn out engine supports. This vibration often disappears when revving the engine high, but is very noticeable at low revs.
You can have these inspected and possibly replaced to reduce the vibration cominf from your engine.
Hope this helps.
Jul 02, 2009 | 1998 Honda CR-V
Honda accrod 04 ex..Blower Motor..A/c Fan
You probably hit one of the veins on the squirrel cage, mounted on the fan motor. You might be able to take the fan out and straighten these, to get the vibration out, if not you'll have to replace the whole fan. Good luck. I hope you can straighten it and don't have to replace.
May 28, 2009 | 2004 Honda Accord
Vibration in my truck at high speeds
I would start with the cheaper problem first, if you live in snow or mud county pull the tires look for mud, ice, then have your tires re-balanced. Not that try wheel aliment
Mar 15, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Broan-NuTone Allure® I WS136BC Kitchen Hood Logo
698 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Marvin
Marvin
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
