Question about Zebra Z4Mplus Label Printer
Z4MPlus barcode printer
When I take lables in my barcode printer, it is getting stuck up in between and is not able to complete the processing. How can i resolve the probelm
  • 3 Answers
Please try to calibrate your printer thru the Printer's Menu.
Posted on Jan 30, 2008
I have had this problem, but only when I used a label of a size that isn't within specification. Technically, this printer isn't specified for a label that is under 1 inch in height. I have a label that is only 0.2" in height and it will get sucked down inside the machine. I have asked the people who work on the manufacturing floor to advance the label two rows after a print job so that this doesn't happen. Then I ask them to cut the label off leaving the two rows sticking out. So, the next print job will start with the label stock sticking at least 1/2 " out of the printer.
I believe that also my printer doesn't tear the labels cleanly, so there is sometimes something that can catch right at the tear bar. You can probably fix that problem if it exists for you by adjusting the tear bar, or having a machinists slightly sharpen it. I hope this helps.
Posted on Jan 10, 2008
We use 2 column lables and when we print the barcode on the second side will not scan. there is missing lines in the barcode.
possible, need printhead replacement. Try to.
Turn printer off,
press pouse button,
turn printer on, still pressing pouse button for 10 seconds, and then relese the button. the printer will print the pouse test with barcode, check if coming with wihte lines across, if yes, change printhead.
Mar 03, 2011 | Zebra Z4Mplus Label Printer
How to know the drivers to install on a cpu
Dear sir...
you dont worry about the just consider the OS only(Operating sytem).search the barcode driver in google with barcoder brand name with model no.(model no specified in the lable of barcode reader)
Example: free download barcode reader for sanion AG1020 driver for vista
sanion is a brand name,
AG1020 is model printed on barcode reader body,
Vista is Operating system instaled in the computer.
Dec 04, 2010 | Computers & Internet
Z4m printer problem
You may have an element or two on the left side of the printhead that is worn out and not printing. The best way to see if elements are not working is to use the widest label you have and run the PAUSE test. Turn the printer off, press and hold the PAUSE key while you turn the printer on. Keep pressing for about 10 seconds and then you can let go. When the printer is finished starting up, a test pattern will print. Part of the pattern is a black box. Any elements that are not working will show as white vertical lines. The only way to correct is to replace the printhead.
Hope that helps !
Jun 09, 2010 | Zebra Z4Mplus Label Printer
Lables getting printed alternatively
This is due to :
Wrong size of label.
You must give a page size and the gap size
It is very important to give the correct height and ga dimensions
The detecting sensor chosen is not the right one
Nov 27, 2009 | Toshiba B-SA4TP Printer
Code Error 6A80
6A80 error is an APP position error. It means that an error has occured when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Oct 20, 2009 | Canon MX700 Office All-In-One InkJet...
Zebra S4M Lable Printer Not Scanning
You might want to check the barcode ratio, bar width, printer speed and printer darkness. I am assuming that you are creating the barcode in some sort of label design package, correct? You either need wider bars, or make sure you have enough quiet zone on both sides of the barcode, so shrinking it might be the solution as well.
Apr 12, 2009 | Zebra S4M Thermal Label Printer
Powering on the Z4MPlus, only have the power light & barcode
with zebra printers for the most part, hold down the power switch for about 10 seconds when powering on.
Mar 24, 2009 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
152 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
