buy a new mixer unless you are able to replace the motor because it is most likely burnt up because we have gone through 6 mixers and the motor slows down and eventually stops and just buzzes
thebsjunk - I don't know if you've canned the old mixer. If you've bought a new KA, congratulations to Kitchenaid. If you haven't, there's still a possiblilty that you might be able to fix it yourself. (For the price of KA mixers you'd think they's last a 'lifetime', but alas, KA quality is sorely lacking from their current products...but I editorialize.)
It's quite possilbe that you've had a gear tooth break in the transmission, which would lock up and prevent the planetary gear (agitator) from rotating in mixing bowl. This is what happend to my wife's 6 Quart Pro KA mixer. Since it was out of warranty, I decided to troubleshoot myself. First I downloaded the Parts List manual from the KA website so I knew what to expect. Then I easily disassemble the mixer to find that a bevel gear tooth had broken. After ordering the correct parts, and reassembling, it works better than when we first upacked it. The loud whining is absent...
If the motors gone bad, you can still replace that, too. Fixing your mixer yourself is much easier than shipping it off to a repair center, and you have the gratification of doing it yourself.
I hope this helps! Howard, Burke, VA
the speed selector switch will not stay "off'. does not catch. any movement of the mixer...
(More)
the speed selector switch will not stay "off'. does not catch. any movement of the mixer causes spring to pull lever out of the off position. Turned on when I was changing mixer tool catching my hand.
when moving, the mixer was placed on its side for a period of time, causing oil to leak out into the...
(More)
WHEN MOVING, THE MIXER WAS PLACED ON ITS SIDE FOR A PERIOD OF TIME, CAUSING OIL TO LEAK OUT INTO THE PACKING BOX. NOW IT GETS HOT AND SHUTS DOWN. HELP
The kitchenaid ice cream maker drive assembly does not fit on to my mixer because of a metal disk...
(More)
The kitchenaid ice cream maker drive assembly does not fit on to my mixer because of a metal disk below the spring on the beater shaft. Is there a way of removing this disk and is it needed?
