Question about Sony Xplod 1200W Class AB Bridgeable 2-Ch. Amplifier w/Variable Low-Pass Crossover
Guitar/amplifier 'buzz' I have recently aquired an electric guitar and amplifier. However i cannot hear the guitar properly for the awful 'buzzing' sound off the amp. I know it is very ignorant of me but i hav'nt a clue how to go about stopping this problem. The amplifier is a vox valvtronix 15amp and the guitar is a yamaha pacifica 112. Thanks a lot Steve
    Champion:
  • 211 Answers
Have you allready connected another cable between guitar and amplifier. Or tried another guitar? When you turn on the amplifier without connecting the guitarcable is that buzzing sound still there? It could be several things, or maybe you are just overdriving the pre-amplfier of your Vox.
Regards,
Gerard
Posted on Jan 31, 2009
I have two amps .i need to know how to set the knobs on them. to get the best sound out of them .i have a crate and a drive elite.i am a beginner. they are both bass amps. so PLEASE HELP ME
Posted on Dec 27, 2007
Am getting a bad buzzing noise from my laney lc15
Bad connection? Loose fittings? I used to get a crackle from my amp when I turned the volume or balance knobs. A quick spray of WD 40 down the shaft after removing the knobs fixed it.
Mar 13, 2016 | Laney LC15-110 Guitar Combo Amplifier (15...
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
Hello! I was recently playing and found out then whenever I play specific notes on any of my guitars, my Fender Frontman 212R will buzz. The notes that always buzz are drop C, drop C#, any A note, and...
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
Aug 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I have noticed a buzzing sound generated from the amplifier when I play my low e string
Several possibilities come to mind:
The speaker is driven too far mechanically causing the voice coil to go into a non-linear region.
The cabinet, stuff inside, grille cloth, or even a logo on the cabinet is resonant and rattles.
Your guitar setup is not quite right leading to "fret buzz"
To troubleshoot, reduce volume and see if that helps...
Mar 04, 2011 | Roland Cube 40XL Guitar Combo Amplifier...
Hi having trouble when i plug guitar or mic into the neo. when i raise the trim to hear the input, the re is a big buzzing sound that just wont go away... any ideas?
Do you have any light dimmer in the house?
Are you using humbucking guitar pickup?
Do the the buzz change when the move the guitar around, it may be picking up radiate magnetic field from the transformers of the equipment.
The preamp is very sensitive with very high gain circuits that amplify signals in the millivolt range, so godd shielding and grounding is needed.
Dec 31, 2010 | Audio Players & Recorders
I play Gibson USA Sgs, one with 490/498 humbuckers and one with 57classics....The Amp has a loud buzz like feedback all the time on the overdrive channel.
If the amp is quiet with cables unplugged at the same settings as observing the buzz, the amp is OK.
In this case, cables and/or shielding and wiring in the guotar is suspect.
Guitar pickups are sensitive to magnetic fields and you can search out these fields by moving and orienting your guitar to find maximum buzz.
If the amp has objectional buzz with teh cables UNPLUGGED then the amp needs servicing. Filter capacitors among other things are suspect.
Sep 12, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
My spider III 15 watt buzzes whenever i have a cable plugged in.
MAKE sure you have it connected to a three wire circuit that has the ground. A lot of these style amps will buzz if they are left ungrounded.
Also search for sources of buzzing light light dimmers.
Further, power supply electrolytic filter caps are suspect.
Aug 23, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Amplifier is buzzing when i plug in my les paul but ok with other
Several things to try:
- Probably already have, but another guitar cord.
- Ground switch on the amp?
- I had an older guitar that buzzed due to the pickups. While touching the strings, all was well - I was acting as the ground then. The ground wire broke, so it buzzed no matter what. The ground wire ran to the metal bridge.
- Play louder than the buzz! :)
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
I have just purchased a Yamaha EG012 and a Yamaha GA-15 Amplifier. I've followed the instructions adn plugged everything in, but when i turn on the amp and adjust the volumes there is just a buzzing noise...
You may have a switch with 2 settings somewhere on your amp - one for active and one for passive. try changing that.
If this doesn't work, make sure you got the guitar in the line input, change the lead for another incase it's faulty, turn the volume up on the guitar to activate the pickups, and rock-out when you find the problem and fix it.
Dec 30, 2008 | Yamaha Electric Guitar
Amp works on off on off
The buzzing is possibly the electrical mains hum at 50hz, all amps have a hum/buzzing... if you have to tap the jack lead between the guitar and amp it could simply be a connection problem, the cable may be old and internally damages, maybe loose wiring on the other side of one of the input jacks
Jay.D Bsc Music Technology
SEO - Web business optimisation and online promotion
Dec 13, 2007 | Audio Players & Recorders
Sony Xplod 1200W Class AB Bridgeable 2-Ch. Amplifier w/Variable Low-Pass Crossover Logo
424 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
