Question about Fargo DTC525 ID Card Printer
Cards My cards are getting stuck in the middle of the rollers.
  • pcking Mar 25, 2008
    cards keep gettingstuck in middle. Also sometime ribbon breaks. in middle of printing. This machine has less than 100 prints and has sat for a few years.
    Sniper:
  • 56 Answers
Hi, try to clean rollers with cloth dumped with alcohol,then use dry cloth again to clean rollers.Also clean sensors.Then go to menu and calibrate sensor. BR.
Posted on Feb 01, 2008
Inner white roller is not working and the paper is stuck in the middle
Look for color green knob and roll it to push out the stuck paper in the middle.
Feb 24, 2015 | Konica Minolta bizhub Office Equipment &...
When i trunn on and when i want print all ways stuck
if you see brown marks on the center top of your page then its your feed roller... hp feed rollers come out easy... Get some rubbing alcohol or hand sanitizer solution and clean with a paper towel... Make sure to dry your feed rollers then put them back in... that should clear up your issue... if that still does not work you may need to replace feed rollers
HP LASERJET 1320 FEED ROLLERS TRAY 2
If it feeds ok but gets stuck at the back then chances are your fuser is bad. The belt is most likely ripped.
HP LASERJET 1320 FUSER ASSEMBLY
Sep 12, 2012 | HPLASERJET1320N LASER Printer INTEGRATED...
How do I get the stuck paper out of a copy mashine?
You will need to take the machine appart. There are usually access pannels for all areas that paper go through for this exact reason.
Apr 13, 2012 | Office Equipment & Supplies
Hi, i have a Brother MFC 7620N and 8 time out of 10 when i'm printing the paper get stuck and then i get this error obviously. My problem is that the paper always get stuck,do you know any idea...
Hi!
It is due to the paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with luke-water and lint-free cloth. I hope this would fix the issue
Hope this helps! Good Luck!
CreativeTECH
May 31, 2011 | Brother Office Equipment & Supplies
Card are stuck in evolis perbelle 4 so we get it by hand and then we have mechanical issues
First check for your card's thickness and adjust thickness lever accordingly.
Take a soft cotton cloth soaked with Isopropyl Alcohol with minimum water content.
Clean all Rollers including one roller below the feeder.
For cleaning Rollers you can take out ribbon and press the push button on front panel.
This will move Rollers and you will be able to clean rollers easily.
Clean the rollers below ultraviolet ribbon sensor and the roller set at output hopper also.
Feb 02, 2011 | Evolis PEBBLE 4 Led Card Printer
PAPER GETTING STUCK BEFOR THE OUT TRAY
hi,
paper passing rollers have dirty. clean the small (rubber, Nylon) rollers on the delivery section. ok
or one sensor hold in (yellow foamed) plate middle of the delivery unit. clean it.
best of luck
Aug 13, 2010 | Canon imageRUNNER 400S Copier
I have a paper jam that i cant get to. The paper is coming out with a line that is crimped in the middle. I can hear paper rolling but cant see anything to get out. The paper that comes out has a line...
Check for any debris or any stuck object inside the unit, it could be a small piece of paper has left inside when you encounter any paper jam problem before.
Better to use a better high quality paper on your copier, it sometimes the problem like this happen because of low quality paper use, the paper roll inside and the paper cannot feed out properly out of the copier.
Let me know for further assistance.
Thank you for using fixya,
Jun 22, 2010 | Canon imageCLASS D860 All-In-One Laser...
The handle on our Marcato Atlas 150 keeps getting stuck and is difficult to pull out for storage. Any ideas?
I opened the rollers to the widest setting (Zero), and placed a folded business card between the rollers. I then turned the dial down so the rollers were "pinching" the card, and while keeping tension on the dial to gently squeeze the card, I gently shook the handle for a few seconds and it came out!
Jan 12, 2010 | Atlas Translator Marcato Atlas 150 Handle...
HP 3210 getting paper jam because label stuck on roller.
I ran heavy card stock through printer several times, it caught the label and pulled it out on the paper eventually.
Feb 04, 2009 | HP Photosmart 3210 All-In-One InkJet...
CHAMPION PAPER SHREDDER
My champion shredder had too many papers go thru because I didn't see the enclosure in one of the flyers. the shredder has now stopped. I have tried to pull the paper out but I reverse the wheel and now the paper is stuck behind the the wheel where I can reach. The motor is now ona humming sound. Are there screws on either end that I can remove the top? Please give advise n what to do. This is not and old shredder.
Oct 20, 2008 | Office Equipment & Supplies
Fargo DTC525 ID Card Printer Logo
137 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
