Question about HP LaserJet 1010 Printer
Bad print hello my printer is printing a dark patch along the left side of the paper. all along from top to bottom can you please give me a suggetion. thank you atis
  • stebeleo Dec 03, 2008
    I have the same problem and I am sure that recently no paper jam..
    Can you explain to me how to resolve the problem?
    thank's for your attention,
    Scholar:
  • 152 Answers
Its leaking ink and the paper is getting dirty.... i am sure that recently it had a paper jam..
if that is so, the problem will cease as soon as the bloated ink finishes.. otherwise, you better send it to a repairman who can fix that cause its a tad bid complicated to explain through this way..
Posted on Dec 27, 2007
Scx4623f problem with printing right side dark and left side deem
Try to remove toner cartridge and shake, plug in and make a self test print. if not work, you need to change new toner cartridge to make sure that the problem is not with printer itself.
Feb 11, 2014 | Samsung SCX4623F AllInOne Laser Printer
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
How to print 2pages on one sheet of paper (side by
press key with windows logo(bottom of keyboard, both sides of spacebar),choice printers and faxes,find printer your using(if you have more than one listed, or the one with check by it),double click, when document box opens,click on printer(upper left at top of box),under page layout choose # of pages per sheet...2 will give you 2 pages side by side,4 will split the sheet into 4 quarters.
Mar 20, 2010 | HP Officejet Pro L7680 All-In-One Printer
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Same Problem - Wet Black Line on back of each printed page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
CF
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 26, 2009 | Canon PIXMA MX850 Multifunction Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Vertical line on Brothe MFC 8460N
PREM
Mar 22, 2009 | Brother MFC-8640D Printer
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
HP LaserJet 1010 Printer Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
