Question about Vacuums
Vaccum dirt devil Model M086365 sucktion not good fan motor woking good filter new bag new just sopped suck good has some but not like it did.
  • 1,673 Answers
Re: vaccum
Check the hose for a clog, also check the dirt inlet down by the brush roll for a clog. If bagless, the filter inside the tank may look good, but if it is old then you may want to replace it.
Posted on Feb 22, 2008
0 characters
3 Points
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
The brush spins but the the dirt is not getting into the bag. i cleaned the hoses now it's not sucking anything up.
If the motor is running you should get some kind of sucktion, if no sucktion or wont blow any air out, check the house making sure is clear of any obtruction, the best way is looking in the house by have one person hold one end and other pull the house straight and look to see any obstruction. if it seem clear, check the motor attach to the fan, yep you have to take the cover to the motor off with phillips screw driver in order to see what causing motor not to **** although the motor may not be attached to the fan; could be loose and not spining the fan to create any sucktion. hope that help some..good luck
Jul 12, 2009 | Vacuums
No Suction
it is probably the dirt fan. u may have to get it serviced
Jul 09, 2009 | Dirt Devil Featherlite Bagged VacuumVacuum
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Changing the belt
there are screws in the bottom take out then use flathead screwdriver on the side pry apart should cum off
Sep 11, 2007 | Dirt Devil M086365 Bagged Upright Vacuum
Vacuums Logo
65 people viewed this question
Top Vacuums Experts
Roger Potts
Are you a Vacuum Expert? Answer questions, earn points and help others
