Question about Fuji FinePix F470 Digital Camera
Can turn my camara on but then the screen goes blank and grey in colour, and switches itself off, but then lens stays out and will not go back in, to switch the camara back on I have to take the battery out and put it back in again, I can press the on button its makes a very small whirring noise and then goes off leaving the lens out, I cant get past this problem, can you help.
  • jeanoffski Dec 27, 2007
    We will try this. Thanks
Try another battery, it's possible current battery no longer viable or needs a deep discharge recharging.
Posted on Dec 27, 2007
Hi I have a fujifilm f470 finepix camera. One
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Aug 26, 2009 | Fuji Rod Repair Kit
Problem with F470 Fine pix camera
sounds like the keypad ribbon has either popped out of it's socket or, and this would be the common fault, the ribbon has broken. In which case fuji will be your only way to fix and get it serviced at the same time. last quote I recieved was £80.
source a donor camera on ebay for the cheaper option
Jan 06, 2009 | Fuji FinePix F470 Digital Camera
I have a Fuji F470 digital camera. It was dropped. Now when I turn it on, the screen displays Finepix, then goes blank.  It seems to take pictures,,,lens moves in and out and flash works, but I can not see...
hi, when you drop it , it broke the color chips sensor , to make it repair , the coast it always arround 125.00 and + , so i sujest , your can try your waranty or buying brand new , ( factorydirect.ca ) they have good price yvon chow !!!
Jan 02, 2009 | Fuji FinePix F470 Digital Camera
Camara says "card not initialized".
hi , you should try your card in something else to see, if it good, i think your car died at same moment as you do your thing , now to know if your cam is ok run wihtout card inside. let me know, yvon chow !!!
Dec 22, 2008 | Fuji FinePix F470 Digital Camera
Camera lens does not retract & view finder is just blue, will not go to other screens
The lens maybe out of track. Perhaps you have bumped the camera or dropped it. Look if the lens are a bit tilted, if so, try straighten the lens with your fingers, very gently. Hope it works.
Oct 04, 2008 | Fuji FinePix F470 Digital Camera
Zoom error
You lens are tilted? If so, they are out of track. Maybe you bumped or dropped the camera. Try straighten them up with your fingers, very gently.
Sep 05, 2008 | Fuji FinePix F470 Digital Camera
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
Fuji Fine pix F470 digital
Shoot, I have the same problem and posted the identical question along with this one. I'll respond her if I hear anything.
Nov 24, 2007 | Fuji FinePix F470 Digital Camera
ZOOM ERROR
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Screen goes blank when capture button is pushed
Seems to be a problem with the camera and the batteries. It thinks the batteries are dead but they aren't, this is the problem I am having with my camera, I'm going to try new batteries and see if there is a Firmware upgrade.
Dec 24, 2006 | Fuji FinePix E510 Digital Camera
Fuji FinePix F470 Digital Camera Logo
79 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
