Question about Trust N12M Network Link (12922) Network Adapter
Transfer Compatible with windows Vista
I have been using a USB2 Easy File Transfer cable between my computers operating Windows XP.
I have purchased a new Laptop with Windows Vista. Is there any way I can continue to use my transfer cable and how do I make it compatible with Windows Vista.
I have tried to load the original driver for it but it fails everytime.
Appreciate any help.
5 Suggested Answers
  • 3153 Answers
SOURCE: windows vista which USB cable do I need to use a
As far as I am aware the mouse you are talking about is NOT blue-tooth but a regular wireless mouse.
It came with a small wireless dongle that plugs into ANY regular usb port and does not need a cable.
Blue tooth does not usually use cables either as it is a wireless format but different to regular wireless
If your mouse is blue-tooth then you should ensure that your laptop or pc also has blue-tooth.
Should it not have blue-tooth then to use the mouse you would need to purchase a usb blue-tooth adapter. this is not a cable but is classified as a "dongle" you that's true !
This dongle plugs into any regular blue-tooth port on occasion windows will detect and install the required files but some blue-tooth dongles will come with a cd that you need to install.
If this information was useful please click
Posted on Aug 16, 2009
  • 11967 Answers
SOURCE: it wont let me transfer pictures to my laptop. i
Use a card reader to download your pictures to a folder you create on your desktop.
Posted on Sep 29, 2009
Testimonial: "thanks for your help"
SOURCE: Problem solved for user wich have Windows Vista and 7
Hi guys, I've solved this problem downloading driver for WB-3400T there is compatible with our WB-3100P and windows 7.. You need to download the driver for for item no. 14383 (without 02, 03 ecc) for vista 32 bit and this will be the driver also for windows 7 for our lovely webcam ;)
Posted on Jan 30, 2010
  • 3606 Answers
SOURCE: Have just replaced a laptop
When you install the software select compatible mode
by right click and select propertises
And select to install in windows xp mode.
Then the program should work.
Hope this will help you.
Posted on Mar 13, 2011
Help for easy transfer cable
If both computers are connected to your network, you can easily enable sharing of the drive(s) on your XP computer, then connect to it from the Windows 8 computer and transfer the files over the network.
Aug 06, 2014 | Belkin Easy-Transfer Cable for Windows XP...
Trying to transfer files, documents and pictures from my old computer Windows XP to my new computer also windows XP, I have purchased through DELL Belking Easy Transfer cable for Windows 7. Can I use the...
Dear Friend
I will rather suggest you for the LAN instead of data transfer cable. By using LAN you can share Data, Documents, pictures, printers, faxes, and storage devices at High Speed.
Mar 14, 2011 | Computers & Internet
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I recently purchased a Dell Inspiron 560S with Windows 7. Our present computer has Windows 2000. I bought a Belkin Easy Transfer Cable and note on the packaging it states for Vista and XP. Will it work for...
Unfortunately, Windows Easy Transfer is not supported on Windows 2000. So I would suggest you to return this cable back and use the manual method of transfer of data from one computer to another. Thanks. Abhishek
Mar 10, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Unable to tranfer files from vista to xp
What is the way you are transferring files? Using any Softwares or other modes?
Try out Windows Easy Transfer -
Sep 16, 2009 | Microsoft Computers & Internet
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Easy transfer cable
Too risky as the cable may or may not be configured for two of the same OS.Transference by CD would be a better option.
Sep 19, 2008 | Computers & Internet
Trust N12M Network Link (12922) Network Adapter Logo
49 people viewed this question
Top Trust Computers & Internet Experts
micky dee
Computer Links
Robin Hill
Robin Hill
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
