Question about Hitachi 60SDX88B 60" Rear Projection Television
Red deflection is way off, picture scrunched into top right corner
The green and blue works fine but the red picture is bent way up into the top right corner. I know electronics but have not got a manual. Last problem was picture shrinking into center and then a snapping sound. TV would sometimes shut off. Cleaned CRT HV caps (rubber ones) and applied HV "glue", waited a day and it seemed ok.
So I do not think the problems are related and am looking for help with this red ctr problem.
Thanks,
Mike
    Scholar:
  • 146 Answers
Call 800-648-6657 order part number CZ01341. This is the convergence output ic. You will need to replace the red convergence output ic IK04.
Posted on Nov 20, 2008
I have a samsung tx-t2782 with red green and blue pinstripe running horizontal across top of screen. not a ground loop and theres no magnetic interference.
hello spins,
If your problem just pinstripe on top of screen , but picture ok (normal in picture), try it to enter the factory mode. In standby position press info-menu-mute-power. Enter to deflection adjustment- choose - vamp (VA) or v shift (VS). Change value data by pressing + (or right cursor) and - (or left cursor) to shift or increasse amp. If it work, your tv will normal.
But its nor working, you should call samsung technician.
Good luck.
Mar 30, 2011 | Samsung SlimFit TX-T2782 HDTV
Convergence issue on Curtis Mathes CM19033S TV
try this will help u when my tv shows the problem i refer to this site onlyhttp://www.answers.com/topic/television-...
Nov 26, 2007 | Curtis CM19033S 19" TV
We went to auto focus on our tv. It shook wildly the when the picture came back the picture is bent. When looking inside the tv the green and red are being projected bent at the top and bottom. Please...
You need to replace the convergence IC stk392 -110...2 resistors and a fuse. located in the deflection board of your tv and after you can press auto focus and the picture will be normal.
Dec 18, 2010 | JVC AV-56WP74 56" Rear Projection...
Ok i have a 47in samsung hd tv today it started acting funny the picture and colors arent right like there a blue red and green colors its like the main picture is being copied 3x times once by each color...
this issue is caused by a failure in the convergence ic's and possibly a bad resistor and fuse in the circuit if you need instrution on how to change I may be able to help though it is kinda tech heavy
Jan 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
TV Has grean red and Blue lines going through it.
Yes this can be fixed. It is a common problem caused by a failure of the "convergence" circuit. Sometimes in this particular set, just a bad solder connection can cause this (though no shop will admit it). Other times its just a simple part on the Deflection board. The repair should run around $300
Mar 20, 2009 | RCA P52926 52" Rear Projection Television
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Part disclored picture
as it has fallen on the floor
due to that its deflection coil position might  have  changed a little.
due to that its left corner has gone down.
deflection coil has convergence magnet on it so due to that there is change in color also.
please call tech to re position of deflection coil every thing will be fine as it was.
as per buying another it is up to you.
hope this will help.
Oct 10, 2007 | Sylvania 6842PE TV
No picture, just red-blue-green lines through the middle of the screen very faint.
The PT-53WX54 is a standard projection set and does not have a bulb. It has 3 separate picture tubes. If you have lost the picture completely, not even on-screen menu, then something has stopped working in your set. It could be a video processor, vertical deflection or possibly a convergence problem. The set should be serviced by a qualified tech familiar with the Panasonic projection sets.
Aug 22, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Hitachi 60SDX88B 60" Rear Projection Television Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
