SOURCE: Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
SOURCE: my bosch dishwasher door will not latch. It
Same model. Mine acts like it thinks it is closed. It doesn't latch, and the cycle still runs when you open.
SOURCE: The dishwasher door does not
The catch is broken on your door.
--- Please dont forget to vote this answer was helpful Many thanks ------
you will need to get engineer to replace it.
SOURCE: Bosch dishwasher #SHU3306UC/12 The door
Hi -
It's almost impossible to repair the latch if it's broken. It composed of fiddly interlocking plastic parts and a spring. When they break, it's usually because one of the plastic arms or spigots has snapped off. There's too much stress on the latch for any improvised repair to last very long. A new latch only costs about $15 anyway, so it's probably not worth repairing.
Bosch part number for the latch is 419827. This is the Bosch authorised substitute for original part number 165243. It may also be worth getting a new connecting rod, which is essentially just a brace. This is part number 263807 and costs about $2. You will also need to re-use the microswitch and the latch cover (color coded for your fascia panel) from the existing latch assembly. Both of these simply clip on to the new latch assembly.
Hope this helps. If you need supplier details or fitting instructions please let me know. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
