Question about Coffee Makers & Espresso Machines
Brewing system jammed - Delonghi Magnifical 3200
The brewing system on my coffee machine is completely jammed. At the beginning, I couldn't removed it, then I gave a few (and small) knocks on the machine and the brewing system went completely at the bottom of the machine. Now it is jammed at this position and I can't remove it. I can't not even place back the tray. How can I fix the problem? Thank you.
  • texsyb Feb 20, 2009
    infuser is at bottom of machine. cannot power off at machine. grounds container light steady but cannot be replaced because infuser will not reposition
  • spoiltbrat Mar 08, 2009
    I have this same problem "infuser is at bottom of machine. cannot power off at machine. grounds container light steady but cannot be replaced because infuser will not reposition" the "empty grounds container" came on then when i went to put it back the infuser was down and wont go up. Still says to empty container.. HELP
Ran into this same problem this week - brew /infuser unit is stuck at the bottom of the machine and it doesn't seem to want to move. Cannont replace the drip tray/grounds catching container. After speaking with Sam a wonderful customer service rep at DeLonghi (866-528-8323) I learned the following that saved me from having to send the machine in for repair which could take 2-3 weeks.
  1. Make sure that the machine is unplugged before attempting this repair process.
  2. Open the front door of the machine so that you can see the brew unit.
  3. Take the grounds catching container only (without the drip tray) and put it into position where it would normally be seated.
  4. Carefully try closing the front door.
  5. If the door will not close with the container in position, carefully reach under the door and apply gentle pressure to lift up on the container so that the door can then close.
  6. Plug your brewing machine in. It should power on and then make an internal adjustment which will raise the brew/infuser unit up enough to then be able to once again replace the drip tray and grounds container back into position.
  7. If it does not raise high enough, try unplugging the machine again, wait about 5 seconds and then repeat the same process just described.
  8. Once you are able to replace the tray and container, power the machine on.
  9. Have a cup ready to place under the dispenser as it will release water and coffee as it preps itself for operation again.
Hope this helps those of you who are experiencing this same scenario.
Successful in Seattle
Posted on Mar 30, 2009
  • tlfathers Sep 03, 2010
    Thanks heaps bowwowboy, your clear instructions awesome, you just saved me at least $150.00. From girl downunder
  • matnab Jan 20, 2011
    Magnifico!!!!! I am now a coffee machine engineer and can function properly in a morning once more.
    Many thanks
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
While Brewing Bin Full Lights Came On
Check the housing where the bin sits is clean and free of coffee and other debris
Apr 18, 2014 | DeLonghi Coffee Makers & Espresso Machines
I think I put in too much ground coffee how can I pull out the brewing unit
Behind the front panel with the unit switched off.. you can then gently pull the brewing unit out and clean it
Apr 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi bco320 t will not brew coffee
The heater element for the coffee brewing side is defective.
Jul 09, 2012 | Coffee Makers & Espresso Machines
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
Jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
Mar 28, 2010 | Solis Master 5000 Espresso Machine
Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Feb 02, 2009 | DeLonghi EC155 Espresso Machine
Brewing System stuck
Hi, I think this is something I encountered once. Try this:
1. Shut the service door
2. unplug the machine, wait for any of the shut down noises to stop
3. plug the machine back in, wait for any noises to stop
4. check to see if everything is back in order
The most important thing is to keep the service door shut, and all the parts, ground basket, drip tray etc. in place. The mechanical will only operate with these things in place.
Hope this helps.
Aug 01, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
2,845 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
