When I turn my Camera on the light turns green,,, It beeps three times,,,The LCD never lights up,,,The lens never pops out, it remains seated. Please help.
When I turn on the Camera no matter which batteries I use the Camera beeps three times the little light turns green for a bit and then nothing happens.When I turn on the Camera no matter which batteries I use the Camera beeps three times the little light turns green for a bit and then nothing happens.
light blinks on then after a pause it beeps 3 loud beeps. i put in a new set of batteries and it did the same, after playing with the power button a couple of times "low battery" display came on the lcd screen and it beeped 3 quiet beeps, i also put in a set of fully recharged 15 min. rechargeable batteries, and again 3 loud beepslight blinks on then after a pause it beeps 3 loud beeps. i put in a new set of batteries and it did the same, after playing with the power button a couple of times "low battery" display came on the lcd screen and it beeped 3 quiet beeps, i also put in a set of fully recharged 15 min. rechargeable batteries, and again 3 loud beeps
You can't post conmments that contain an email address.
This explains the 3 beeps. also says you can get it repaired which is by far the best option. The behaviour is very typical of low battery state. Try a set of Lithium batteries.
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at [email protected]
Try checking to see if the lens is a little crocked, look at it real closley.If it is then try and pop, or bend the lens back into place, and then turn your camra on and the camra may work propelry.
I had the EXCACT smae problem, and it worked for me.
So it may hlep you too.
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one: -turn the camera on -click on Menu button -select options using left/right, up/down button -select Set up 2 -Select Battery type -Select Alkaline for non-rechargable or Ni-MH for rechargable -click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
I turn the camera on, it beeps three times, then goes off.
