Question about Nakajima AE-740 Typewriter
Return sticks when i hit the return key the carriage sticks at a point that isn't the left margin. if i hit margin release, it just beeps at me. i have to manually push the carriage back to the left margin to reset it. but then it does it all over again.
  • Anonymous Mar 19, 2008
    how do i clear the margin settings on the Nakajima AE-740 typewriter
  • Nakajima Master
  • 3,594 Answers
Try putting a few drops of light oil on the shaft that the carrier rides on and the pulleys that the cables are on (WD40 works well) also look for debris under the carrier.
Merry Christmas
DickyO
Posted on Dec 28, 2007
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
How to clear and set margins and tabs please on
You must hit the carriage return button to find the current position of the left margin, then hit the mar release button and use the backspace key to move the carriage to the new position that you want the margin to be set at, then hit the left margin key to set it. Then move the carriage to the right to find the right mar, hit the mar release key and use the spacebar to move the right mar to the new position you want, then hit thr right mar kay to set it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 02, 2009 | Office Equipment & Supplies
Swintec 640 margin release
If it is the left margin, you touch the carriage return button to find the current position of the left margin, then touch the mar release button and backspace to the new left margin location, then depress the left mar key. You should here a beep. You are done.
Jul 22, 2009 | Swintec 7040 Typewriter
How do I get the left hand margine to release on my Royal typewri
Generally yoy can set the left margin all the way to the left by holding down the left margin key and pushing the carriage return button
Mar 23, 2009 | Office Equipment & Supplies
Coronomatic 2200 carriage return stops advancing
It sounds like you are coming up against your right margin. By hitting release you are merely bypassing the margin. You might try resetting your right margin by clearing it all the way to the right side of the carriage first then resetting it to where you want it.
Jan 28, 2009 | Office Equipment & Supplies
Margins will not reset
Return to the stopping point, press and release the mar. rel. key backspace to the left then press L. mar. key.
To clear tabs tab all the way yo the rt. press & hold tab clear touch ret all tabs should clear.
Hope this is helpful
DickyO
Jul 11, 2008 | Nakajima AE-740 Typewriter
Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Nakajima AE-740 Typewriter Logo
113 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
