I have an HP media center pc the m370n, and i just upgraded to windows 7 ultimate. I can not get the tv tuner to work, what could be wrong? thanks. Ryan
Comments:
Oct 15, 2009
- I have run that before in installed it and everything passed with a GREEN checkmark.
Even the 2 drivers that it is apparantly blocking because of windows problems came up on it and they both have a green checkmark saying run windows update after installation and it will work, i have done that and it still does not work :S....
Oct 15, 2009
- I ran that driver smart program and apparantly everything is ok...
I looked inside the computer and found ASUS on the green board and the numbers C1VA82 and SN 3ACG0C7078
If that helps....
think you'll find the drivers for the tuner are not compatible with windows 7. according to the hp website this is an xp machine. download the windows 7 compatibility checker from here to check http://www.microsoft.com/downloads/details.aspx?familyid=1B544E90-7659-4BD9-9E51-2497C146AF15&displaylang=en
- all the checking I've done indicates this tuner model to be 4-5 years old and I cant find anything newer than the xp driver you currently have.
I believe win 7 should have an xp mode, have you tried this?
Other than this I've reached the end, sorry.
when i switch on my zenith desktop by pressing the CPU button, green light is glowing, cd drive...
(More)
when i switch on my zenith desktop by pressing the CPU button, green light is glowing, cd drive light is glowing but the red light of CPU is not glowing. Finallym the computer is not getting switched on. please help as this is happening very ofter
With power on, a "power button lockout" will appear on monitor and monitor will turn black...
(More)
With power on, a "power button lockout" will appear on monitor and monitor will turn black and will lose all research I have accomplished?????????
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2...
(More)
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2 halves are glued together? Can you supply a disassembly instruction pdf, or a sevice manual?
i brought a pc x200 from asda on 31-8-09 with vista pre. used it a while until ive got my main pc...
(More)
I BROUGHT A PC X200 FROM ASDA ON 31-8-09 WITH VISTA PRE. USED IT A WHILE UNTIL IVE GOT MY MAIN PC FIXED. ON REUSING PC AFTER A NUMBER OF LONG UPDATES I GOT BLUE SCREEN ERRORS. AM I RIGHT IN THINKING I CAN GET UPGRADE TO WINDOWS 7 BEFORE 2010. THANKS YOU IF YOU CAN HELP ME ON THIS PROBLEM AS I DONT WANT DO FRESH INSTALL WITH VISTA AND AS IT A NUMBER OF YEARS SINCE IVE BROUGHT A NEW PC .NOTE S/N WO01272299 [STOCKPC 648] KEVIN HURFORD
