Question about Watches
How to set the time in the clock
I am unable to set the time in the clock when new battery is replaced
  • jrfrog Mar 08, 2008
    I took the old battery out,  replaced it with a new one(Energizer 2025),  got the
    polarity right(positive away from the body of the watch).    Put it back together and,  nothing,  blank screen.   Took all apart,  tested the battery,  is OK.
    Any suggestions?   I liked this watch because it was very cheap,  had
    only what I needed,  and nice color.   I bought three,  and previously
    replaced a battery in another, no problems.
    Thanks,  John
My daughter got a Columbia digital watch for Christmas and lost the instructions. How can we set the time, etc.   Thanks!   Darwin
Posted on Mar 30, 2008
I have a radio controlled clock I bought from Aldi I cannot get the time to set from the time signal can you help please
Depending on where in the world that you are, the time signal might bot be strong enough to reach you.
Dec 18, 2012 | Watches
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 | Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    I have a Sunbeam Westminster Quartz mantle clock I bought approx 17 yrs ago and after replacing the battery and setting the time again the clock stops after an hour or two. Any ideas of what the problem...
    mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
    Jun 23, 2010 | Watches
    How to set the clock how do i no the battery good just got it
    If the watch is not running it's probably the battery. To set, pull the crown out and turn to adjust the time. Push the crown in to run the watch. If the watch is new the battery should be OK but take it back to the store if it doesn't run. If you bought it used take it to any watch shop for a battery replacement. Sears does it for about $8 or less.
    Apr 28, 2010 | Movado 0604771 Wrist Watch
    Setting watch after battery replacement unable to set watch
    Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
    Make it as big as you need.
    Hope this tip helps
    Dec 26, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    I am unable to set the correct time since putting in new battery
    Try this one(paste it in to your browser):
    Jan 07, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Can't set time zone
    Try pressing and holding the -CF for three seconds then press it again. The P (Pacific Time) appears, press it again and the M (Mountain time) appears, etc.
    Nov 21, 2007 | Watches
    Watches Logo
    189 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
