Question about Pioneer TS-A6962R Car Speaker
Rear deck speaker install
I never installed speakers before I am trying to install a pair of Pioneer TS-A6962R 6x9 speakers in my 2004 Chrysler Sebring on the rear deck. I have the factory speakers out but dont know how to wire the new ones
  • skinner91 Jan 02, 2008
    I have pioneer TS-E6996 speakers i have fitted them but the connections on the speakers themselves do not have + or - on them. they are different sizes and the wires going into the speaker are different colours (black & black and white). Would you be able to tell me which one is positive and which one is negative!?!?
Posted on May 28, 2008
    Problem Solver:
  • 14 Answers
I'm assuming that you have left the original wiring intact? If this is the case then it's a pretty simple thing to do. There should only be 2 cables one for each speaker & each cable will have a positive & negative polarity. Once you have securely fixed the speakers into place (usually screwing into place through the mounting holes provided) you just need to attach the wires to the speakers. If your car has manufacturers plugs on & don't match the speaker ones (quite often the case now) simply cut them off & replace with spade connectors of the right type/size. The most important thing is to get the polarity the same way round for both speakers!If you get them reversed you will NOT get any bass. Also remember with any new speakers they need time to run in & sound their take it easy with the volume control for the first 20hrs or so of play if you want them to sound great & last longer!
Posted on Dec 28, 2007
go to call them and get wire harnesses for them they carry all of them and have directions for install.
Apr 05, 2010 | Pioneer TS-G950M Coaxial Car Speaker
Can I connect the left front and rear together and same on right?
you can.. im guessing your trying to do that to "bridge" the amp to put out more watts.... you can do that but it puts a lot of strain on the amp that is pushing the speakers..(the radio)
Oct 18, 2009 | Pioneer TS-A6962R Car Speaker
Need help installing 6x9s into a chrysler 300m can't get to the rear trunk speakers to install the need one
if you have 60/40 rear seats, fold them down, if not remove the seat back(a firm tug at the corners should do it) the rear deck(where the speakers are) should lift up. this may take a little gentle persuasion.(the trim on the sides of the rear window may have to be removed as well) this should expose the factory 6x9's and they're mounting screws
Oct 02, 2009 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
Need to install a pioneer cd player to a DEH-1550. Can I please see a diagram?
the easiest way if u still have ur harnest in tacked in ur car go to ur radio store and get a kit and a wire harness kit and match the colors. if u dont first get a volt tester with a light first find ur poewer and constant. constant will turn ur light on auto matic. the power will turn on when u turn ur igintion. once u find them put them aside now the rest of the wires. get a AA baterry and try one wire at a time once u hear a pop thats the first speaker tape it together. and do the rest to the rest of the wires
Jul 03, 2009 | Pioneer TS-A6962R Car Speaker
Remove rear headrest
Jun 02, 2009 | Pioneer TS-A6962R Car Speaker
Speaker Wiring Troubles
A loose connection with your speaker wire... This does tend to happen time to time. Just reconnect the speaker wire.
Mar 31, 2009 | Pioneer TS-A6962R Car Speaker
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Feb 28, 2009 | Pioneer TS-A6962R Car Speaker
Need To Install pioneer ts-g950m speaker in my car
i did this with mine, hook more wire to the wire that holds the clamp , then solder it or wrap it around the terminals on the speakers
Jun 06, 2008 | Pioneer TS-G950M Coaxial Car Speaker
Pioneer TS-A6962R Car Speaker Logo
314 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
