Question about Minolta magicolor 2400W Laser Printer
Service Call 17H
My magicolor displays "service call 17h", error light constantly flashes, no print.
Anything I can do myself or should send to repair shop?
Thanks
  • Zoomboy Dec 27, 2007
    In addition I can't rotate the color cartridges.
    Any help willl be appreciated as I am slowly collecting sludge hammer and plieres.
  • Anonymous Mar 26, 2014
    there is a error ocour during print the error code is 0094
Had this message 17H after unpacking the Magicolor 2300 W.
Here's the step by step way to fix it, done with the help of an online technician on the phone.
Cause : one of the toner cartridges was unproperly installed in factory, or went loose during transport, so the whole toner rack is out of synch.
Solution : manually take out and reinstall ALL cartridges and reboot.
Time : 10 mins
IMPORTANT 1 : turn off the printer and UNPLUG it as you need to "erase" the error from its memory.
IMPORTANT 2 : this is a manual intervention, byp*ssing the electronic-*ssisted way to replace cartridges. As such, there's a risk to damage the unit.
IT'S YOUR CALL :D
How (you need to use the printer parts'names in the small manual):
1. Take out the waste toner bottle.
2. Release the transfer unit release blue lever clockwise to upper position (11:00)
3. Pull out the OPC drum cartridge and hide it in a box away from ambiant light
4. Now the fun part....
5. The toner cartridges are to be pulled out through the oval hole in the upper left corner. PLACEMENT IS CRITICAL.
Chances are there's not a cartridge ready to be pulled out as the rack is out-synch, u probably see 2 cartridges through the hole.
You need to manually rotate the rack for each cartridge BUT YOU MUST ACTIVATE ITS FREE-WHEELING FOR THAT.
DON'T FORCE THE ROTATION, YOU CAN DAMAGE THE UNIT.
6. About 1 inch to the left of the hole, there is a tiny rectangular hole with a circle button inside.
Use a flat screwdriver to push this button about 1 inch inside and hold it there.
(You know you're doing well if you can rotate the rack with one finger, almost like a bike's wheel...)
Then you can manually rotate the rack and take out each cartridge. AGAIN PLACEMENT IS CRITICAL, DON'T TRY AND FORCE OUT THE CARTRIDGE.
7. Take out all 4 cartridges.
8. Put them all back again, make sure you respect the color code (ie. C cartdrige is C slot, etc.)
9. Put back OPC Drum, etc.
10. Plug the printer and restart it.
That worked for me, the blue cartridge was indeed loose, no more 17H.
Best regards,
Taipan
This message was edited by taipan on 6-3-05 @ 2:52 AM
Also read that you could try turning the machine on and hit the change toner button. If it lets you change toner, then remove all the toner cartridges and install them again and see if that clears it up.
Posted on Jan 20, 2008
Thank you! Worked great. In my case I only got it after reinstalling my black cartridge; I only needed to spin it and replace that one to get it to reset.
Posted on Apr 15, 2008
17h error, paper comes up the back and stops gives this error
Error 17H is a rack rotation failure:
The toner cartridge(s) may not be sitting correctly, which would be the easiest fix - otherwise you have to carefully examine the inner workings of the printer itself, to see what is causing the rack to get jammed or slowed down at some point along the way.
Nov 20, 2010 | Konica Minolta magicolor 2400 Laser...
Service Call: 17H Call Technical Support
refix ink cartridge and check there is not paper jam .
Apr 21, 2009 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17h
17H is the Rack Rotation error. If your toners are not rotating correctly, or if you have the wrong type (IE 2400 series toners in a 2500 series printer) you will get this error.
Feb 18, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta 2300 DL
Just sent you the manual.
Regards
Wayne
Oct 02, 2008 | Konica Minolta magicolor 2300DL Laser...
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Incorrect cartridge fatal error 17H
Replace with OEM cartridge
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 18, 2007 | Minolta magicolor 2350 Laser Printer
Service call Message
Hi. A 17H error indicates that there is a toner rack rotation failure. There is a good chance that at least on of the toners is not seated right and that is keeping the rack from rotating right. If you can select "remove toner" on the display that is on your printer, remove all of the toners, then select "install toner" and reinstall all of them. Also, you will want to check for any physical damage or anything that may be jamming up the toner rack. There could possible be a piece of paper jammed in the right side of the rack. Hope this helps. Good luck.
Jun 30, 2007 | Konica Minolta magicolor 2500W Laser...
Minolta magicolor 2400W Laser Printer Logo
1,596 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
